-   -   Interference Engines (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/175984-interference-engines.html)
nynor 08-12-2004 09:26 AM
actually, at one time, and maybe they still do, porsche made a 911 motor for use in aircraft with timing gears, no chain, no belt. so it can be done, and it MUST be reliable.
jm951 08-12-2004 09:42 AM
In some domestic V-8 set ups, the chain is eliminated with gearing. There are two main reasons for it- 1)it insures valve timing through eliminating any possibility of chain stretch and 2) eliminates the possibility of chain breakage because of forces generated by radical, high lift cams. As the engine rotates, the cam undergoes a series of "jolts" as the valves are actuated. If strong and frequent enough, these jolts can concievably damage a chain drive, hence the reliability for uses like aircraft.
Lawrence Coppari 08-12-2004 09:52 AM
Mercedes has used chains in their aluminum engines for many years. The chain on my old 1980 450 is about 6 feet long. The engines are durable and there is no problem with thermal expansion and chains. My 1980 has 150K on it. The chain was replaced at 100K. This engine is far from a performance engine.
On the other hand my 400E has 32v and 4 cams. It is also chain driven with an aluminum block and heads. It could be considered a performance engine. It's redline is about 6K.
My 18v V-6 AMG supercharged MB also is aluminum with a chain drive. It is definitely a performance engine.
So I would tend to say that chains can be used with aluminum blocks.
jm951 08-12-2004 10:28 AM
I'm not saying they can't, but how are the chains tensioned and what mechanisms are there to keep that tension constant?
VINMAN 08-12-2004 11:07 AM
There are chain driven valve trains that use spring loaded tensioners.
VINMAN 08-12-2004 11:09 AM
also the amount of tension on the chain is such that the effect of thermal expansion would be miniscule.
Lawrence Coppari 08-12-2004 11:37 AM
The old one uses springs, plastic sliders, and an oil pressure piston thing. I have never worked on the 3 and 4 valve engines so I don't know how they are arranged.
rb101 08-12-2004 04:35 PM
Don't forget about the need to oil the chain/gears. But this could be a good thing. Only the crank seal and timing chain cover gasket need to be replaced, when it starts leaking, instead of the 4 seals now.
