bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
Brake Booster valve install help
Hey guys, my new brake booster vacuum valve just got here and I'm trying to install it. I got a new rubber grommit also.
I tried putting the grommit in first, then tried putting the valve in that, but it's sooo tight i'm afraid of breaking something. Should I put the grommit on the valve, then put it in the booster? Is there some secret to wedging these mofo's in there?
Thanks,
Bryan
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 08-05-2004, 10:43 AM
I couldn't get the valve installed with the new grommit, so i gave the old grommit a try. It seemed a little bit larger, and it was a lot easier to get installed.
I'm worried, though, that the problem might not have been the valve being too tight in there, but that I was fighting the vacuum. Because the valve went in so much easier, i'm worried that it will leak.
Old 08-05-2004, 12:02 PM
Try using a little dishwashing soap to lubricate the rubber.
Once seated propelry, the valve will press right in.
Larry
'86 944 w/240,000 miles
'87 944S 16V w/247,00 miles
Old 03-28-2006, 10:00 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You can also test for leaks using ether or WD-40 and see if it sucks it in. If it doesn't you should have a good seal. If it does suck it in, your rpms should go up.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-28-2006, 10:14 AM
