Driver
Gauge cluster is out!
So I got the instrument panel out & (apparently) didn't break anything (thank you Clark's garage ).
2 questions:
1. What are the direct replacement lights for the directionals, high beam indicator etc? They are all the same bulb, I just don't know what it is.
2. On the top left of my gauge cluster there is an indicator window blacked out and no bulb behind it. Obviously for an option I do not have. Does anyone know what goes in that window? My guess is the ABS light.
Thanks,
GHEN
'87 944
Old 08-05-2004, 03:51 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
a 194 is the recommended replacement but after the thread on the super bright LEDs I'd like to give those a try. I wouldn't go with a higher wattage bulb than a 194 'cause you will probably melt stuff. Also search Clark's Garage for the article on brightening your dash lights - must read for what you are doing (got to fix those nasty light guides, makes a big difference.)
The warning lamps are W1.2W (ECE) or 2721 (Mazda)
good luck,
nate
1988 944... and a bunch of other cars
Old 08-05-2004, 05:40 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Use 194 replacement LED's...MUCH MUCH MUCH better lighting...and you can choose your color.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-05-2004, 05:44 PM
are the dash lights outside the gauge cluster also 194's? If so I might try switching to red (miss the cool cockpit effect of my old Bimmer)
nate
Old 08-05-2004, 05:53 PM
Not sure....haven't gotten that far yet...lol.
Old 08-05-2004, 05:56 PM
Which dash lights toolboy? In my early ALL the gauges use 194s, but the lights behind the heater control etc are not. Since it doesn't work I haven't replaced them...couldn't tell you what they are.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 08-05-2004, 06:47 PM
I actually have a late 944, was curious about the heater controls etc. - if I can't easily switch those to red as well I will probably just try the white LEDs, I hate seeing two different colors on the dash
nate
Old 08-05-2004, 06:49 PM
Custom User Title
rammstein's Avatar
mackenzie- I considered using LEDs. I have seen single LED non-directional bulbs, 4 bulb clustersm and 6 bulb clusters. Which have you used?
I already resurfaced my reflectors, and it made a HUGE difference.
Old 08-05-2004, 08:01 PM
Driver
On my car there are three bigger bulbs on the bottom that utilize the reflective bulb housings. There are several other bulbs that luminate the directionals; etc. They are much smaller. These are the bulbs I am talking about.
I appreciate the help.
GHEN
'87 944
Old 08-05-2004, 08:24 PM
Send a message via AIM to bluebullet
i put LEDs in my bottom 3 illumination spots (i have an 85.5), but they are stupid dim. I think the fact that they are directional lighting is not helping because the main beam is is not being absorbed into those reflective mirror things. Instead of using more money to fix that, how can I make these work? Shave down the side of the bulb? resurface the mirror?
I didnt wire them in...i bought the push in bulb replacement ones..if i can bend them somehow (likely impossible cuse they have hard plastic bottoms) to face more towards the plastic it would work better.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 08-05-2004, 09:59 PM
What bulbs did you buy, exactly, Blue? LED's are remarkably bright...you shouldn't really have that big a problem unless you're running an odd voltage...
Old 08-05-2004, 10:05 PM
nige944's Avatar
Originally posted by FR Wilk
The dash lights on the late 944 are 2W. The conventional brightness fix is to use the 4W bulbs found in the side markers that are the same physical size.
Tried that before i tried LEDS... but it caused a "hmm whats that burning smell".
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 08-09-2004, 07:20 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Installing LED's is pretty tricky, I ended up making my own set for the late dashes. You have to face them straight down. You are best off buying a few LED's, 3 resistors, and 3 new bulb holders, and making your own set. Depending on preference, you will need either 2 or 3 LED's per bulb holder.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 08-09-2004, 08:44 PM
