-   -   Oil cooler hose ? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/176365-oil-cooler-hose.html)
944freak 08-06-2004 12:37 PM
Oil cooler hose ?
What size wrench does it take to remover the oil cooler lines from the block? I was getting under there to replace the seals and realized I have nothing big enough to take off those hoses.
944 Ecology 08-06-2004 02:22 PM
36 mm, plus about a 32 mm to counterhold the adapters.
Good luck,
GB
944freak 08-07-2004 01:15 PM
can you get a wrench that big in there, or do you use an adjustable wrench or something? What is the Porsche tool for it?
944freak 08-08-2004 02:59 PM
bump
rb101 08-09-2004 02:12 AM
Pelican parts has the 32mm. I'm sure you can find one about. Check Sears. I think they have tools.
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_oilsys_pg2.htm#item7
944freak 08-09-2004 08:32 PM
do you take it off from the bottom or remove the manifold and take it off from the top?
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
