Send a message via AIM to Jmasters
carpet removal
Hi, I am having trouble removing the front section of carpet in my 84 944. I was tring to get the carpet out in one piece but, it ripped on me, I don't really care about the old carpet as it is getting replaced with some good carpet. I can't seem to get the carpet out from under the center part of the dash, in front of the shifter. Does the dash have to be removed to replace carpet? Anyone have any tips on how to remove the carpet? , I have tried pulling on it , but it just rips, I have tried scraping under it, but can't get to the upper part, as it is almost touching the bottom part of the dash.
thanks
SOLD 1984 944 NA, Fr Wilk PowerProm, rebuilt engine, blisten shocks front and rear, 220lb springs, adjustable 968 rear sway bar SOLD
Old 08-07-2004, 06:08 PM
Driver
Take out your center console, it worked for me.
'87 944
Old 08-07-2004, 06:09 PM
center console is out as is everything else except the dash
Old 08-07-2004, 06:26 PM
entertaining the idea
UconnTim97's Avatar
If I remember correctly, I think there are a few screws from the center console, behind the stereo etc, that are going through the carpet. Also you may just have to pull on the carpet to cut it, and pull the rest out from the other side of the console.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 08-07-2004, 10:23 PM
I'm having the same problem. Seem like way up behind the dash is the only place where the glue is still good...
'84 944 currently converting interior to black (among other things)
Old 09-29-2011, 05:44 PM
Send a message via AIM to msailer
It is being held in place by the heater housing. The three early 944s that I have taken the carpet out have had the same problem. So you have two choices. 1- Remove the heater housing and then you can pull it out, which I think would involve removing the dash. 2 - Take a razor knife and cut the carpet as close to the heater housing as you can.
Good Luck.
Old 10-05-2011, 07:08 AM
