what part is this?
I bought an 83 944 which has damage to the driver side front suspension. The tire rubbed inside the wheel well and also rubbed a hole in a black canister, behind the fender directly behind the wheel. I havenít had a chance to look at it in detail but I cant find anything that looks like it in parts catalogues. The best I can tell the inside looks like a filter and I didnít find any fluid in it. Just trying to find out what this thing I is so I can replace it.
Old 08-08-2004, 12:16 PM
It's a charcoal canister. I'm not exactly sure how it works, but I think it's suppose to minimize the fuel vapors that enter the cabin.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 08-08-2004, 01:22 PM
Yes, it's the charcoal canister. It's part of the evaporative emissions controls.
The idea is that it collects the fumes evaporating from the fuel in the fuel tank, and, under the proper conditions, is fed into the intake manifold to burn through the cylinders.
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 08-08-2004, 02:31 PM
TCMdocs944's Avatar
Get one from a used parts yard.
You can probably source one from automobile atlanta (online) etc.
I would just patch it up with some sort of epoxy. You need it airtight or you will experience vacuum gremlins. Check the top plastic nipples where the lines insert as well, they could be cracked and needing repair.
Good luck.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-09-2004, 08:09 AM
