84 transmission
The transmission in my 1984 944 NA just died. Any idea what year transmissions would fit without any modifications?
Old 08-09-2004, 06:42 AM
winter-hater club member
nynor's Avatar
1984
"COOL PRIUS!" - Nobody Ever
Old 08-09-2004, 07:05 AM
Anything up to early 85 will fit. 924S will fit, but 5th gear is lower.
After 85/2 should fit, I can't remember whether the casting bosses for the trans mounts are on the later trans. 944S/S2 and Turbo have the wrong ratios.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-09-2004, 07:15 AM
nige944's Avatar
I believe anything upto a 1987 will fit, hang on i'll see if i can dig out the link.
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 08-09-2004, 06:27 PM
nige944's Avatar
You need an 016k Transmission(assuming its a stick), if you follow the link and scroll down you can see which other models use the same transmission.
This doesnt work both ways... i.e. older models (<85.5) can have a newer transmission, but i think in >85.5 944's the speedo connector is to the transmission(or something like that), so you cant fit an older tranny to a newer car.
http://www.connact.com/~kgross/FAQ/944faq02.html
Old 08-09-2004, 06:42 PM
I read somewhere the 944 uses an Audi Gearbox. Is that the case and were these built for Porsche or were they used in certain Audis as well? It would no doubt be cheaper if buying VW parts than Porsche or am I mistaken?
Old 08-10-2004, 05:57 AM
