Mein Gott!
Panzer909's Avatar
16 Valvers: Hall Sensor question(s)
So I'm inspecting the engine bay after a long road trip last weekend, and the plug fitting to my Hall Sensor is starting to (literally) crumble and fall apart. Its still connected and there's no change in any idle behavior or the such, but exactly where does the plug wire come from? Its coming from somewhere under the cam gear, but are these things easy to replace? any idea for the cost of this plug?
Any part number would be appreciated; I called my local dealer and he had no idea what I was talking about
Thanks!
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 08-11-2004, 05:09 AM
The wire comes out of the harness that goes between the back timing belt cover, and the front of the water pump. Sometimes the wire gets caught between the valve cover and the distributor cap housing (the black painted timing gear cover) I believe the oil pressure sensor leads also connect to the same portion of the harness.
Find the water temperature sensor, under the water outlet. (the thing with the coolant bleed screw in it). the connector that hooks to the water temperature sensor connects to this part of the harness as well.
Mike
'92 968
'01 VW Jetta TDi
Old 08-11-2004, 06:52 AM
The plug gets brittle with the age of the car and exposure to engine heat. As long as the wire connectors dont touch each other, it should be fine. If you can secure the socket so they won't come off the metal bracket it will be better.
The part number for the distributor hall sensor is 94460617001. OEM distributor charges about $150 and dealers about $190. Check with OEM Porsche parts. I am not sure if Pelican sells one.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 08-11-2004, 03:35 PM
Mein Gott!
Panzer909's Avatar
Thanks for your imput, guys.
$150 for a small plug - gotta love it. I'm starting to keep a running tab of S-S2 only parts that are wildly expensive. Among them, its own exhaust (it looks almost identical to the 8v n/a but is different, cams, tensioners, ect. Ouch.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 08-13-2004, 07:19 AM
peterjcb's Avatar
What exactly is a Hall sensor? It that the plug that sits on a small metal bracket on back of the distributor housing?
I think that I might have messed the plug up trying to disconnect it during my recent water pump/ belt job.
There were three wires in the plug.The red connector broke loose from the connection so I soldered it back and the car seems to be running OK. It won't fit in the bracket anymore because the plastic just fell apart so I fastened what's left of it to the metal bracket with a nylon tie.
I was thinking of eliminating the plastic connection completely by just cutting and soldering the wires together. Good or bad idea?
Grand Prix White '86 951
AUTOTHORITY MAF SETUP / stage 2 chips
Previous: Black '87 944S - sold after 4 years
Old 08-14-2004, 04:39 PM
That is not a bad idea. You can save your $150 and spend it on something else. Don't forget to shrink tube the solder joints.
2018 Suburban Z71
Old 08-14-2004, 05:10 PM
peterjcb's Avatar
What functions of the engine do those wires control ?
The previous shop that did the last water pump / belt job on my car 4 years ago did a pretty shoddy job. The Oil pressure sending wires were routed in FRONT of the timing belt cover and only 1 wire is connected. My oil pressure gage is always reading 5 when I start it up. There is also a problem with the connector on the oil pressure sending switch.
Old 08-14-2004, 05:24 PM
Mein Gott!
Panzer909's Avatar
Great suggestion, Peter. I'm gonna just get a .15 cent nylon tie and tighten the pieces of that crumbling plug together. Its so bad right now that you could flick it off the metal bracket with your pinkie finger.
I believe those wires are used to figuring out which cylinder is "predetonating" (knocking). Regardless, I don't think the other wires you described should be where they're currently at. Doesn't sound like your previous wrench was 100% familiar with these cars.
Pretty car on your site, by the way.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 08-14-2004, 05:51 PM
..P ..P is offline
man I ran those plates, and you've been a bad boy!!!
P
(nice car BTW)
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 08-14-2004, 06:31 PM
peterjcb's Avatar
It was the PO's mechanic that did the job 4 years ago according to the receipts that he gave me. I decided to do the job myself and get it right.
While doing the water pump job and looking around under the car I noticed some hanging wires that do not appear to be affecting performance but I want to get the oil pressure gage working correctly and tie up all the loose ends.
Old 08-14-2004, 07:12 PM
FR Wilk, with the Hall Sensor connected, would you know what's the maximum (factory) retard possible?
Tom
Early '85 944
Old 08-15-2004, 09:49 AM
thanks for that and as long as you are looking things up, is 6 the maximum for the turbo's too?
Tom
Early '85 944
Old 08-15-2004, 02:18 PM
peterjcb's Avatar
I eliminated my crumbling Hall sensor plug today by just soldering the wires together and eliminating the plug.
The Hall sensor wires are NOT color coded to the harness wires. I had to spend some time digging out the resin in the plug figuring out the connections.
On the Hall sensor plug there are three wires:
1-Red
2-Green
3-Black
The harness wires are colored:
Light Tan - goes to the Red on Hall sensor
Brown - goes to the Green on Hall sensor
Shield wire - Goes to the Black on Hall sensor
It worked fine for me. In fact it feels a lot smoother. I changed my Mobile One oil & filter also ....she's purring like a kitten.
Old 08-15-2004, 03:10 PM
Mein Gott!
Panzer909's Avatar
Well it looks like its time to resurrect this thread, as my Hall sensor finally gave up the ghost nearly seven years later. Was tinkering and the hall plug simply fell apart. Now I'm trying to put it back together but need to I need to confirm the correct order of the pins. So it looks like (looking from left to right) the colored pins should go red-green-black. Can someone confirm this?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 08-01-2011, 05:54 PM
Mein Gott!
Panzer909's Avatar
Come on - nobody???
Fair enough. So now I have another question. I recently developed a backfire while on heavy throttle at higher RPMs. Changed the plugs out and it ran a little better, but do you think it could be related to the crumbled Hall sensor?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 08-23-2011, 06:15 PM
Mein Gott!
Panzer909's Avatar
bump
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 08-25-2011, 05:21 AM
jetmax's Avatar
Send a message via AIM to jetmax Send a message via Yahoo to jetmax
Mine just went. How are you guys fixing this? Can I get a photo?
1990 944S2 Cab - over 215k miles
jmaxvill@hotmail.com
Old 06-11-2013, 03:44 PM
Either buy a new one or get a reference sensor connector kit and rewire it.
-Doug D.
87 951 - Satin Black Metallic - well equipped
90 S2 Coupe-Silver- corner carver
Old 06-11-2013, 06:41 PM
Aussie944S's Avatar
I just bought a new one cause mine looked crappy.
Old 06-12-2013, 01:15 AM
I just soldered and shrink wrapped mine.
Will get the wire color diagram i made up and report back.
tks gary
Old 06-12-2013, 06:53 AM
