-   -   Calling ALL cricket owners (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/177350-calling-all-cricket-owners.html)
ronniebaldino 08-12-2004 05:05 PM
1. What on earth are the correct tensioning specs for the timming belt and the balance belt?
2. Where the H3LL do you put it to get an accurate reading?
Help.
I have been standing in front of my car for almost 2 hours and I am not confident enough with what I am doing to drive the car to get the tension checked.
Thanks guys,
ronniebaldino 08-12-2004 05:24 PM
Nope, that was the one I was using. No matter how hard I pushed on his back I couldn't get the "clicking" noise. All I heard was a "crunch". I tried with two more but same noise. I figured it may be the belt so I took it off and threw on a tube sock. Gonna tension it tommorow once I have the correct settings.
ronniebaldino 08-12-2004 05:36 PM
Socks?
speed 08-12-2004 06:28 PM
http://arnnworx.com/SmileWavy
ronniebaldino 08-13-2004 04:53 PM
I have read 40 for new belt and 28 for used one. I have also read 38 for used one. That is ALOT of difference.
Also, all the pictures for placement are on early models without the spring tensioner. I know I should be ok with just that but I want to be sure. How do I use it with the tensioner? I don't seem to have any room.
AFJuvat 08-13-2004 07:41 PM
If you have an auto-tensioner, just loosen the two nuts on the tensioner and let it move to a new position, then tighten the nuts again.
AFJuvat
ronniebaldino 08-14-2004 06:02 AM
If you say it is o.k. then that is what I will do. I did that but I just kept wondering? How does it diferentiate between a new belt and a used one? I would assume that it has only one tension setting. I guess in abot 2000km or so I will release it again to re-tension the stretched belt.
Should I drive it somewhere to get it checked right away or just have faith in the tensioner and re-tension later.
Also, should the belt be at the front edge of the cam pulley or a couple of mm back from the edge?
I will let the tensioner out and then tighten it again. roll the belt over a couple of times then go back to TDC and do it again. Does that sound good?
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
