aLmost finished with my 944... goes into body shop for a full strip/respray... completed engine rebuild and replaced multiple body seals,,,, even have the under engine cover ready to bolt on... new fog lamp lenses & bulbs on order... new decals, emblems and stone guard pieces ready & waiting.. planning on wilks chip upgrade next...
Dash fixed, working on replacing the gear on the odometer... Leather is okay, no cracks, but will be dyeing it over with black leather dye... carpet is not worn, but very dirty and water stained,,, tried a carpet shampoo machine and it helped... anyone find any chemical solvents which will get water stains out of the rugs? |
entertaining the idea
I just replaced the carpet this summer. It is not difficult at all.
You may want to consider that after all of the other work you have done....
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
btsave, did you do most of the work yourself or did you have it all done?
Also, do you have an excel or similar spreadsheet of how much you have spent on your car? I'm interested in sort of "restoring" mine but I've been wondering about costs.
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender |
was your dash cracked? did you replace it with a new one? im tryin to see how big of a job it is to remove it..
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5 |
suck my tail pipe
Dash replacement is a big job.. windshileld must come out.. gfood luck BB
Hi UconTim.. long time no see..
My car is naughty |
1, Dash was deeply cracked, put a nice dash top piece on and it looks fine.. Will probably replace the entire dash if I ever need to replace the windshield as the grain is not exact... but only I notice the difference.
2, Did about 1/3 of the work myself overall, here's the breakdown: Purchase price '83 944 $2000 Shipping from CT to FL $ 500 Repair Dash Top (self) $ 80 (25 minutes) Miscellaneous parts for interior, engine bay, etc $230 Used cargo cover for hatch area $70 Full engine rebuild, all belts, seals, filters, adjustments, manifold porting, timing, motor mounts, tranny mounts, bushing replacements, sway bar refitting $3000 (inc. labour) Tune up $300 parts (my labor 3 hours) New Blaupunkt radio, new speakers, new "hidden" antenna since the '83 had an external & no antenna wire in the windscreen; $300 (2 hrs labor) Fog Lamp lenses, bulbs, decals, 944 insignia, $150 Prep for paint job, removing exterior antenna, alarm key switch, etc. $ 0 (12 hours) Professional block sand and paint $2200 (estimate) Prep and redo Fuchs wheels $ 15 paint (15 hrs labor) Redyed leather seats $25 dye (3 hrs labor) Total apprx. = $8830 (I know, for an '83 944? but it looks and drives BETTER than new when done correctly!) 3, Future plans include Wilk's chip, window tinting and (Maybe) new carpet set. 4, BTW Amercian Collectors Insurance, under their classic auto insurance program, covered the 944 for just $44 per year, full coverage, with a 5000 mile annual limitation... worth checking if anyone uses their 944 on an occassional basis, rather than a daily driver! What type of cost is there for a new carpet set and can it be done by someone with little experience in that area? Thanks |
Darn, American Collectors Insurance denied me because I've had my license for only 3 years.
Hey Frank! Glad to see your posting again....
Dog-faced pony soldier
If you have to worry about the cost, don't bother.
Seriously. I've got $6K into mine and counting - car is in pieces in the garage and needs roughly $3K worth of mechanical parts more, $1600 worth of new seats (ouch) to be reasonably "done". After that, there's always the paint job (estimates range between $3000 and $7000 for something good) cup wheels (about $3500 for a set of 4), and other minor upgrades (not necessary to run, but sure will be nice) - the ones I'd like to eventually get will be about $5000. Seriously, if you're on a budget and want to restore something, get a VW beetle or a 1978 Buick - stay away from Porsche.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
You can save significantly on the paint job if you do much of the prepiaration on your own.. remove all mirrors, spoilers, block sand the body, etc. The less the painter needs to do, the lower the cost.
IMHO, Restoring a Porsche is really not that much more expensive than doing an MG or Jag... parts are 3 times as expensive and much of the mechanicals are beyond us "shade tree" mechanics... but, if you can reuse & recondition many of the parts, you will save $$$. Since the post '80 Porsche's use galvanized steel, rust is not an issue (except under the battery), so the body work can actually be cheaper than other marques! I have close to 40k in one of my British car restorations... and 20k into a morris mini... so price depends upon the level of restoration, rather than the vehicle. My 944 will be a "cheap" restoration, it will drive great, look like new... for under $10k. But there will be areas that are not original... in a concourse restoration, the cost comes in finding original equipment and restoring that to concourse condition.. |
suck my tail pipe
Good work on the restore..
Maybe that show "overhaulin will come steal my car.. and I can act all concerned about it while they do a monumental job restoring my pile.
My car is naughty |
Thread Tools | |
Rate This Thread | |
