livewirevoodoo's Avatar
Chirping / Whistling Sound
'87NA Automatic, 80k..
For the past 2 weeks I've noticed a cyclical chirping / whistling sound (sounds like a nest of birds...) almost directly under the center console/shifter area. All belts are new (within 5k) so i'm ruling that out.
Anyone have any quick ideas of what it could be so I can follow up on it?
Thanks in advance.
Old 08-15-2004, 12:59 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
and while you're at answering his question...is the fuel pump supposed to be noisy? anywhere above 5k there's a loud low-pitched whistle coming from the rear of the cap proportional to the engine speed.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-15-2004, 01:18 PM
Doh! Forgot to mention: It happens as soon as the car starts running... Park, Neutral, Drive, etc.. It is constant from Park to 80mph (atleast when i can hear it over the exhaust).
Old 08-15-2004, 03:34 PM
TSNAPCRACKLEPOP's Avatar
could your belt cover be touching a belt?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-16-2004, 05:34 AM
sounds like you are going to have to open up the hood, and look in there, got a stethescope? ps pump?
Old 08-16-2004, 06:26 AM
SoCal Driver's Avatar
The only thing rotating under the shifter is the drive shaft and rubber damper on the flywheel. Could be one of the bearings in the drive shaft. If it was the rubber seperating in the damper you would be hearing a lot of noise.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-16-2004, 10:34 PM
