Starter Just Clicks
I have a 1985, late model, porsche 944 that just makes a clicking sound make I turn the key. I put a new battery in it and had a new soleoid installed in the starter. When I put jumpers to the starter it works. The engine is not siezed, does anyone have an idea what the problem is? all electrical parts seem to work
Old 08-16-2004, 10:18 AM
winter-hater club member
nynor's Avatar
bad ground? bad switch? sounds like the starter is not getting enough AMPs.
"COOL PRIUS!" - Nobody Ever
Old 08-16-2004, 10:49 AM
How can I find out if it is not getting enough amps?
early '85 944 -project car, sort of works.
Old 08-16-2004, 10:58 AM
What are 911 fuchs, nynor?
Old 08-16-2004, 11:00 AM
nynor's Avatar
my 944 has fuchs that originally came from a 911. i also have the cookie cutters which are mounted with snow tires.
Old 08-16-2004, 11:20 AM
where is the electrical part of the ignition switch?
Old 08-16-2004, 11:46 AM
Re: Starter Just Clicks
Barring anything out of the ordinary, the bushings in the starter are seizing or the brushes are just about gone. A free-run test of the starter means next to nothing. Listen to me - this is the voice of experience talking. 28 years (so far) as the ASE Certified owner of a starter-alternator rebuilding business.
Doug
Old 08-16-2004, 02:32 PM
Thanks alot Doug, I will take your advice.
Old 08-16-2004, 03:56 PM
Try this quick test.
1. Trace the solenoid wire. Remove it from the starter solenoid
2. Get a 5 foot jumper wire and hook one end to the solenoid. Leave the other end free and and let a friend hold it close to the battery (+) but not touching!
3. Put car in NEUTRAL. Engage parkbrake.
4. Turn ignition switch to ON.
5. Tell friend to hook up jumper wire free end to battery positive (+)
6. If car starts, your ignition switch starter positive contact is bad.
7. If car does not start, starter is bad or seized.
Hope this helps.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 08-16-2004, 04:42 PM
Send a message via Yahoo to Cebu
If the solenoid has been replaced..and there is still just clicking from the starter, then it is likely that the field/armature winding are bad in the starter. Or, the power cable from the battery to the starter is corroded internally causing high resistance and low starting amperage to the starter.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 08-17-2004, 05:31 AM
the car still just clicks and I put a new starter in.
Old 08-20-2004, 09:46 AM
jm951's Avatar
Check the GROUNDS!!!
This is the usual cause for this problem and extremely cheap to fix- like free if you do it yourself.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-20-2004, 09:58 AM
grounds, on the battery? all other electrical componets seem to work would a bad ground the battery allow these things to work? What other grounds could it be?
Old 08-20-2004, 10:23 AM
jm951's Avatar
Check the ground from the engine block to the firewall (located just below the cam tower) and check the ground from the battery to the car. If there is just a little corrosion, sometimes not enough to see, or if the connection is a bit loose, you'll get these exact symptoms. And yes, the other electrical systems in the car draw far less current that the starter motor, hence, they can work, while the starter just clicks.
Old 08-20-2004, 10:49 AM
thanks for the advice jm951 I'll try that and see what happens.
Old 08-20-2004, 05:51 PM
AFJuvat's Avatar
weak battery...
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-20-2004, 08:20 PM
the alternator is dead!!
Old 08-21-2004, 03:00 PM
I had this problem and it turned out to be a bad ground
04 infiniti G35
Old 08-21-2004, 04:44 PM
I had a similar problem. It turned out to be a short circuit on the cold start/thermotime switch circuit. What does your battery voltage read when you turn the ignition? does it drop considerably?
Old 08-23-2004, 11:34 PM
where is the cold start/thermotime switch circuit
Old 08-24-2004, 02:41 PM
