-   -   cylinder head studs (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/177978-cylinder-head-studs.html)
one1cat 08-16-2004 04:20 PM
cylinder head studs
does anyone out there know what the cylinder head studs should be torqued to ? on 85.5 944 na
nynor 08-16-2004 07:08 PM
really f'ing tight...
according to my shop manual:
1st step (tightening the head on the new gasket): 20 Nm
2nd step 50 Nm
3rd step 90 Nm
ae1969 08-16-2004 08:46 PM
I am pretty sure that they updated the shop torque values.... to
1st step 20NM
2nd 90 degree torque turn
3rd 90 degree torque turn.
wait between each torque at least 15-30 minutes...
P.S but I have used both torque sequences with no ill effects.....
944freak 08-17-2004 04:12 AM
The printout i have says
step 1 15 lbs
step 2 35 lbs.....i think
step 3 67lbs
is this right?????
Porsche-O-Phile 08-18-2004 04:36 AM
Just out of curiousity how do you install them anyway? Is there some kind of reverse-threaded tool that they come with? I was considering upgrading to the raceware studs but was wondering how much of a PITA this would be, or whether it's even worth the trouble. Very few problems reported with stock studs.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
