rotor stuck to hub
Believe it or not, I got my front right rotor off of my car. Additionally, I got the 5 retaining bolts removed successfully. But, as though to strike me down yet again, the rotor appears to be stuck to the hub by some type of devine intervention. PB Blaster has not helped, a hammer has not helped, and no matter how much I yell at it, it remains stuck. Help?
PS. Thanks a million to youz who have gotten me to this point, I am SO close to my goal of being roadworthy by Wednesday night. |
which side of the hub are you beating on?
studs down, inside of hub looking at you, some blocking under the brake disc, and a few taps on the hub will dislodge it, (make sure to tap in a clockwise/counterclockwise direction) if that dont work... well get a bigger hammer and repeat :) hope that helps |
MAke sure you are pounding on the right side of the rotor.
as adida said, bigger hammer. AFJuvat |
| All times are GMT -8. The time now is 06:39 PM. |
