944freak's Avatar
Send a message via Yahoo to 944freak
Question whats this?
On the back of the head theres a water line going to the hater core or something on the firewall. On that waterline, the part attached to the head, there is a sensor or something of some kind that looks like it should have 2 vacuum lines going ot it. What is that and if something hooks to it where does it comefrom/go?
1983 944
Old 08-17-2004, 04:42 AM
daxdog's Avatar
Can you post a pic?
1984 Porsche 944 Silver/Black
Old 08-17-2004, 06:46 AM
SoCal Driver's Avatar
Which car?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-17-2004, 08:27 AM
944freak's Avatar
Its on the 86 na engine thats in the 83 now. There is some type of screw in sensor looking thing with 2 plastic nipples on it for vacuum lines but i dont ever remember taking anything off of them. Its located on the only line thats connected to the back of the head.
1983 944
Old 08-17-2004, 10:45 AM
Just thinking out loud
mattdavis11's Avatar
The 85.5's and newer had vacuum controlled heater core valves, correct? The older models didn't, they were manually controlled via a cable. I'm not sure though.
91 FJ80
84 Ram Charger
Old 08-17-2004, 12:49 PM
Think this is on the oil filler/breather?
If so it operates the valve for the charcoal cansiter. I think I have posted illustrations of these vacuum lines before. Should be the same for the early as well as the later 944 N/A's.
Do a search with SoCal and Vacuum.
Old 08-17-2004, 12:53 PM
speed's Avatar
this one
1985.1 944n/a
Old 08-17-2004, 07:46 PM
944freak's Avatar
thats it...number 28, I have no idea what it is but i figured out what hooks up to it. Thanks a lot guys.
1983 944
Old 08-17-2004, 10:15 PM
944freak's Avatar
does it matter which vacuum line goes on which prod?
1983 944
Old 08-18-2004, 03:25 PM
speed's Avatar
yes
1985.1 944n/a
Old 08-18-2004, 08:25 PM
944freak's Avatar
lol....how do i figure out which one goes where?
1983 944
Old 08-18-2004, 10:52 PM
944freak's Avatar
could this have something to do with why my car wont start....which vaccum lines go on which nipple on number 28?
1983 944
Old 08-19-2004, 10:55 AM
AllPorsche944's Avatar
944 Freak, there should be a vacum hose diagram on the left (passeger) wheel well in the engine compartment (unless somone removed it) I will take a look tommorrow to see if I can figure out some guidance on which each leads to...
88 944na = Azure Blue
New Rebuilt Race Engine (@190 HP)
Lindsey Racing Fuel System
MSD Ingnition System
Zimmerman XDrilled Frt/Rear
BB Headers & Cat Back Exhaust
Mass Flow Air w/ Ingen Technology
Nology Pro Fire Wires & Coil
Millie Cup Wheels and Kuma's
Old 08-19-2004, 09:55 PM
That sensor is a temperature operated vacuum switch which is designed to open when the coolant temperature reaches 58 degrees Celsius.
When the switch is open, vacuum is applied to the evaporative emissions cannister purge valves. This vacuum comes from the front most port on NA throttle bodies. The vacuum signal is very small, about 5" Hg or so, and is only applied just as the throttle plate comes open.
The system is designed to purge condensed fuel vapors collected by the charcoal cannister located in the driver side wheel well.
Having this disconnected should not prevent the engine from starting or running. However, if the port on the throttle body is not plugged you will have a vacuum leak.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 08-20-2004, 06:08 AM
