Major brake problem
Please help. I finally got my 83 944 back on the road today after a major overhaul. After going a block down the road I felt the brakes sticking a little. At first I thought it was the emergency brake sticking, but it wasnít. Somehow my brakes are building up pressure as I drive the car. I donít know if something is wrong with the vacuum or what. Now I have a brand new rebuilt motor that has gotten hot because of the brakes are locking up. This car seems to be nothing but trouble.
04 infiniti G35
Old 08-17-2004, 03:33 PM
The brake pedal is all the way up. There is plenty of pedal pressure. I tried disconnecting the vacuum to the booster and the pedal became very stiff.
04 infiniti G35
Old 08-17-2004, 03:41 PM
I disconnected the vacuum to the booster and I am able to drive it down the road, with no power brakes. Is this a symptom of a bad master cylinder? I always thought those just allowed air into your system.
04 infiniti G35
Old 08-17-2004, 04:08 PM
Thank you for your help. Turns out the pedal was not adjusted right. Now if I could only figure out all these other problems.
04 infiniti G35
Old 08-20-2004, 04:40 PM
