Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Cool 2300 miles ans 3k more to go
Well,
I dont post too often but this I think is note worthy. I just finished a trip from San Diego to Cimmaron NM and back which ended up to be around 2300miles. On the way out through Pheonix the car ended up being really hot, (over the 3/4 mark, for me 1/4 is normal) and the lower radiator hose blew. This sucked because I had just replaced it because the old one had a cut in it. Fortunatly it had only slipped off and the other people I was travelling with got coolant for me and it was fixed. I left the A/C off for a long time after that and later even with it on it ran hotter then normal but about 1/2 to 3/4. the next 600 miles the car would do 80 but not as easily as it had before, it basically would not accelerate in 5th.
After my 11 days backpacking, I pulled the plugs and found that they had bit the dust. 50 miles later I found a place that had the right ones and changed them. After that the car felt much better and I ended up also managing 29mpg. Which is a far cry from my normal 17.
So now that i have most the bugs worked out later this week I will be off again across the country from CA to NY for school. So I will be making a huge diagonal up to Rochester. That will make for well over 5000 miles just this summer. right now its at 174800 and runs great.
My only question is that I have a bra for the car and I had it on but took it off when it over heated, I havent had a chance to put it back on but does anyone know if it cuts off enough air flow to make a diffrence? I would like to keep the front end clean. My normal temp is on the bottom mark but in desert heat with A/C it was just below half and slightly above the quarter mostly.
-Greg
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 08-17-2004, 06:30 PM
Feelin' Solexy
Tishabet's Avatar
Cimmaron? Were you going to Philmont?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 08-18-2004, 05:43 AM
Will work for parts
944 boy's Avatar
Yes I was, our treck was 11 days and roughly 78 miles.
Old 08-18-2004, 10:17 AM
Feelin' Solexy
Tishabet's Avatar
Cool, Philmont's a great place.
-grant the Eagle Scout
Grant
Old 08-19-2004, 10:25 AM
