Question engine almost stalls
Does anyone have a suggestion?
When pulling away from the driveway, my engine nearly stalls for a moment. It suddenly loses power and then jumps back. This only happens the first time in the day that I start the engine. And it only happens after I back the car out of the garage. Going is reverse is fine, but trying to move forward causes the problem.
Can anyone suggest where I should look?
Michael John DiSanto
1989 944 S2
Old 08-18-2004, 02:52 PM
Non Compos Mentis
Is this before you've had your morning coffee?
Step on the gas a little bit before letting out the clutch.
Now why is my tongue stuck over in my cheek?
Old 08-18-2004, 09:20 PM
Eli K's Avatar
when was the last time you had a tune up (ie. plugs, cap, rotor, wires, air filter, etc)? Most of the time bad plugs will cause your car to run rough
Old 08-18-2004, 09:44 PM
Everything is up to date in terms of maintainance. The problem is slowly getting worse so that a year ago I noticed a very small hesitation or power loss, but now it almost stops.
1989 944 S2
Old 08-19-2004, 06:52 AM
