cooling problem fix
for all those who have cooling problems for no reason at all...meaning system is bled...thermo is good...fans are running...
I know whats wrong.....
The New owner that i sold the last 44 to called me. The car has always run warm off an on. Could never find out why after replacing almost the whole cooling system.
I refered him to a known 44 mechanic guru in the area.
The problem was that the passanger side fan was wired backwards, working against the other fan...
Boy did i feel like the dumbass. (i didnt wire it backwards, it was already that way when i bought the car, i just never checked)
Ive read several posts about cooling probs for no reason, just thought it could help. Check your wiring....
Current: 1973 914/4 project. FOR SALE
Old 08-20-2004, 12:59 PM
Also had the same problem with my driver side fan running backwards. I almost gave up on my a/c compressor clutch problem cycling on and off due to high discharge line pressure when engine at idle, came to find out the driver side fan was blowing hot air back to the radiator and condenser. Usual previous owner do-it-yourselfer caused problem.
Cut wires and solder the splice and heat-shrink insulation. Problem fixed.
I still wonder how the fan motor ran backwards when PO could have used the same wiring harness and plugs on new cooling fans???
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 08-20-2004, 02:10 PM
