-   -   Need help....because I am helpless (no really!) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/178635-need-help-because-i-am-helpless-no-really.html)
chapstic2001 08-20-2004 01:04 PM
Can someone tell me the details fo the hex head screw on a 951 rear caliper (i.e. lenght, thread count etc...)? This would be the screw that holds the halves together with the little metal bracket. I am coming down to the situation to where I am going to have to get it machined out. With that said they may have to re-tap it and want to give them as much detail as possible so they do not go too deep and wide. I cannot find it on PET. It may be there but I could not find it. Much appreciated.
AFJuvat 08-20-2004 06:33 PM
Are you referring to the two capscrews on each side of the caliper that holds the body to the center piece?
If so, M12x1.5x40
AFJuvat
chapstic2001 08-20-2004 07:20 PM
I believe so. I will take a picture of an example to make certain we are on the same page. Thank you AFJ, you never let me down.
-Prost
Don 944 LA 08-20-2004 09:52 PM
AF Juvat http://www.pelicanparts.com/support/smileys/wat6.gif http://www.pelicanparts.com/support/smileys/wat6.gif http://www.pelicanparts.com/support/smileys/wat6.gif http://www.pelicanparts.com/support/smileys/wat6.gif http://www.pelicanparts.com/support/smileys/wat6.gif
We should be glad to have a proper wrench turner to call on..
and he usually doesn't get upset about the lack of knowledge :eek:
speed 08-21-2004 06:44 AM
I would think a machine shop can read the tap...
chapstic2001 08-21-2004 08:42 AM
I was able to find them in PET but there is no description other than "repair kit spring plate." AFJ, were these the screws you were thinking of?
http://forums.pelicanparts.com/uploa...1093106535.jpg
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
