Need Help asap. on the road now
jhelgesen is on the road right now. Im on his way to destination.
He's having some strange noises he said comming from (seems like) right under or behind the drivers seat at speed.Ir at rear wheel. Its intermitent. Sometimes when turning. A loose sounding rattle?????? Wheel Bearing, half shaft? Loose exhaust? No vibration though... Any ideas?
Current: 1973 914/4 project. FOR SALE Last edited by mambodave; 08-21-2004 at 08:35 AM.. |
Probably one of the things that you mentioned.
None of them would require IMMEDIATE attention, but should not be forgotten. gb
Good luck, George Beuselinck |
CV joint, if it changes pace with the speed your going. Not an immedite threat but should be fixed ASAP.
