try to figure this one out !!!!!
85.5 944. The instrument cluster has for some time on occasion stopped working. It would always start back though. No pattern to it at all. It has gone out now, and can't get it back working. I cleaned both grounds under the dash on the drivers side. Took the cluster out and replaced with a cluster that I know is good. Dosen't work either. Took the original cluster and cleaned the plugs. Still not working. One other thing. When the cluster dosen't work, the sunroof dosen't work either.
Please help!!!!!! Don't have speedo, scared of getting ticket.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 08-24-2004, 02:19 PM
TCMdocs944's Avatar
All fuses checked
Wiring around fuses checked
These fuses can "look" good and be bad
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-24-2004, 03:10 PM
s928s's Avatar
Chect the "lifting roof relay" may be bad or a connection related to the 2. There are 2 red/white wires on the relay, one goes to the spedo head, should be pin 15 left side connector ( red/white).
also on the same relay for the "lifting roof" the black/white wire goes to the speed sensor on the spedo but my digram is faded and does not show the exact pin. I would try to locate that relay and un plug it to see if the spedo works, swap relays and back track from there.
sounds more like it is related to the black/white wire side of the circut that goes to the actual speed sensor. I believe the other is used as an ignition feed trigger.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 08-24-2004, 04:02 PM
s928s's Avatar
looks like the s/r relay is in spot #2 on the relay board # 944-615-117-02. looking at under hood panel right front corner, second one back.
autowerks9
Old 08-24-2004, 04:17 PM
I'll try pulling the roof relay and see if that makes a difference.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 08-24-2004, 05:29 PM
bearone2's Avatar
i guess you could slow down to keep up with traffic 'til you get it fixed.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-25-2004, 02:09 PM
Sometimes there is no one around to pace behind. New police chief here in Nashville was shocked at how fast folks drive, decided to crack down, and boy have they.....
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 08-25-2004, 04:00 PM
Just thinking out loud
mattdavis11's Avatar
Keep the confines of the pcar to Goodlettsville, and drive something else when you have to go into Nashvegas? With all the parts you have lying around, maybe you could retrofit an early front left hub assembly, cable, then mount the speedo somewhere visable? Just kidding.
91 FJ80
84 Ram Charger
Old 08-26-2004, 08:30 AM
ya right
You are right. You would think with bits and pieces of 5 944's laying in the garage, I should be able to get a guage cluster to fire up !!!!!
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 08-26-2004, 03:17 PM
