DumasDemon84's Avatar
Flickering ! light in gauge cluster
I drove my 944 to a softball tournament this week-end to a town about 40 miles away one way. On the way down there and way back i noticed the little red ! light flickering. Sometimes it would stay on for a couple of seconds the go off. Since i don't have an owner's manual i was wondering what this light is and why it would just flicker. It doesn't do it in town just on the highway at about 70 mph or 90 or higher.
Thanks in advance for your help.
1986 Guards Red 944 Auto
1995 Chevy Tahoe 3-3 drop, w/ 22's
2006 GMC Envoy
1989 Dodge Shortbed(project)
Old 08-24-2004, 07:37 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
so off topic but...
YAY ANOTHER PANHANDLER!!!!!!!!1!!one!!
I'm in Gruver, you in Amarillo or Dumas?
Where exactly is the red light?
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-24-2004, 07:39 PM
He's talking about the exclamation point light, at the top of the guage cluster(on 85.5+ cars)
Maybe your parking brake lever is loose and is moving up and down when you go over bumps and such?
Old 08-24-2004, 07:44 PM
Name kinda gave it away. Amarillo sounds better. The light is right above the turn signal i believe very top of gauge cluster. Go Demons and Greyhounds!
2006 GMC Envoy
Old 08-24-2004, 07:45 PM
hahahah....the greyhounds have sucked for a decade...well, at football, anyways...
Yeah...I thought that was the light but didn't know. It's the general warning light...like the "check engine" light. Can we pull codes on our cars? I would check all sensor connections. What's your other guages do?
Old 08-24-2004, 07:48 PM
Everything did work until recently my mpg needle seems to have quit or is stuck. All the rest of the gauges are working fine.
2006 GMC Envoy
Old 08-24-2004, 07:56 PM
dash light
When that big exclamation point light comes on another littler light on the dash comes on as well. Next time it blinks look for some word in red to appear.
Old 08-24-2004, 08:06 PM
adida(r 944)'s Avatar
hey havnt seen you post for awile there DumasDemon84. did you get your shifter worked out, still need those parts?
check your brake pad sensors see if they are loose or if your pads are worn.
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 08-24-2004, 09:10 PM
Ok, here's the update. this light now stays on all the time. So i looked for another light or word like WaA420 suggested and sure enough the little red light at the bottom of the oil pressure gauge was on. I shut the motor off let it sit for a while the checked the oil which was fine. Any ideas? Adidas sorry i hadn't replied, i was thinking of selling my car but i think i'm going to keep it so i might need them after all. Thanks
2006 GMC Envoy
Old 09-02-2004, 08:53 PM
Is this a low pressure or low oil level or what other function does this light have? Oil level seems to be fine. There is also a rattle when i rev up the engine in Park as if there was something loose or something.
2006 GMC Envoy
Old 09-03-2004, 11:31 AM
Get ready to buy a new engine!
That sound is the rattlesnake in your crankcase that is getting ready to bite... (i.e. rod bearings!)
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 09-03-2004, 12:00 PM
Are you serious? If this is true that will be the end of my Porsche ownership. Man i hope you're wrong. Thanks anyway.
2006 GMC Envoy
Old 09-03-2004, 04:42 PM
ae1969's Avatar
Send a message via ICQ to ae1969
In the late cars as far as I recall the ! will flicker for a few reasons...
- emergency brake connection loose.....
- brake fluid level low (or connection at the wires loose)
but since you mention that the oil pressure light is on as well...
If the oil pressure guage light is red as well (guage below 1 bar)........ like 944ecology mentioned you are having oil pressure problems and this is no good. It could be broken pick up tube, loose crank bolt, rod bearings, oil pump etc......
P.S no engine codes generated by dme for you to pull on these cars...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-03-2004, 04:52 PM
Wouldn't the needle stay at the bottom if i was not getting any pressure. It reads about 5 and goes down to about 3.5 as it warms up. Anyone want a 944 auto for about $2500?
2006 GMC Envoy
Old 09-03-2004, 05:03 PM
ae1969's Avatar
??? you also mentioned the little red light turned on ..........ON the oil pressure guage? it will only turn on if its dips below 1 bar... so is that light on or not when it is running.....
5 to 3.5 is normal.
If the light on the guage is off.......check the 2 other items I mentioned..........
Old 09-03-2004, 05:15 PM
The ! light is on and the light on the oil gauge is on BUT the needle still reads 5 to 3.5 like i mentioned. Any chance the sensor is bad?
2006 GMC Envoy
Old 09-03-2004, 06:25 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
do you have a mechanical pressure gauge? if so then hook it up and see. otherwise I would probably gamble that the sender is bad and replace it and see what happens. Yes the light and the gauge are driven off two different connections on the sender.
nate
1988 944... and a bunch of other cars
Old 09-03-2004, 06:50 PM
Thanks, i'll try that.
2006 GMC Envoy
Old 09-03-2004, 07:36 PM
Exactly where is this sender located? Man, this Porsche ownership thing is no fun!
2006 GMC Envoy
Old 09-04-2004, 11:57 AM
My 86 Auto Did the same thing. It turned out to be the oil pressure relief valve
Current: 1973 914/4 project. FOR SALE
Old 09-04-2004, 05:47 PM
