88 motor into an 86 944
is this a basic swap? will the tranny for the 86 work with no problems? are these engines different at all?
Old 08-25-2004, 07:47 PM
88 into an 86
The 88 engine is a direct bolt in. The only Difference is the 88 has higher compression and a 32 bit DME making 160 horsepower compared to 143 horsepower. It will bolt right in.
Old 08-25-2004, 08:04 PM
cool man sounds good.. I've got aftermarket exhaust, throttle body, chip, and K&N intake, will all these bolt on?
Old 08-25-2004, 08:08 PM
hey... someone said Im going to need the computer with the 88 motor.... does that mean that I can't use the motor from the 86?
Old 08-26-2004, 12:38 PM
crap I meant to ask if that means I can't use the computer from the 86?
Old 08-26-2004, 12:39 PM
Where did you the aftermarket throttle body?
early '85 944 -project car, sort of works.
I dunno, I didn't buy it, the previous owner did, it says something on it so I'll let you know what it is tonight
Old 08-26-2004, 12:42 PM
so about that DME... what if I dont have the 88 dme, I only have the 86 dme with the chip.... will I be losing power? will it even run?
Old 08-26-2004, 06:20 PM
SoCal Driver's Avatar
Higher compression means the engine most likely has a knock sensor like the turbos and the 16 valve 944S engines. Then yes you need the DME and the harness. Now you may be able to use the 86 DME IF you can find someone that can re-chip it for your car.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-26-2004, 09:28 PM
TCMdocs944's Avatar
Throttle body is probably a stock one that was bored to a larger diameter. Expensive.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-27-2004, 05:46 AM
