kayw's Avatar
Send a message via ICQ to kayw Send a message via AIM to kayw Send a message via Yahoo to kayw
idle speed adjustment
Hi all, Got a problem... recently I uninstall and clear the throttle body. Then screw it back. The idle speed goes 1200 rpm in stable. I guess I did mess up something during the uninstall and install the throttle body. Just want to know how to adjust the idle speed?? My car is 944S2 (driver side on right -- Hong Kong) 1989 Thanks!! Kay
Old 08-26-2004, 09:28 AM
AFJuvat's Avatar
That oddly shaped screw on the throttle body. You need a 7 or 8mm wrench to adjust it. that is what controls idle.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-26-2004, 04:31 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
AFJuvat
7mm wrench? I just use a flathead screwdriver - or sometimes even a housekey - to adjust my idle on this screw
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 08-26-2004, 06:48 PM
kayw's Avatar
Hi,
What is the "oddly shaped screw"?? Thanks
Kay
Porsche 944S2 (3.0L, NA) 1989 -- rare in Hong Kong
Old 08-26-2004, 07:05 PM
Writer/Teacher
CJFusco's Avatar
there is a large-ish flathead screw on the throttle body, below and to the left of the throttle cam. Turn it one way, idle goes up. Other way, idle goes down.
Old 08-26-2004, 07:09 PM
Writer/Teacher
CJFusco's Avatar
Old 08-26-2004, 07:34 PM
kayw's Avatar
Hi, thanks for reply.
However, my car is not same as yours... the throttle body is different. Mine is a 944 S2 3.0L engine (1989)
also, I didn't see similar screw on the throttle body too.
Thanks.
Kay
Old 08-26-2004, 07:39 PM
Writer/Teacher
CJFusco's Avatar
hmmm
just check on the throttle body and see if there are any random screws that don't seem to be bolting anything down. Turn them while the engine is running...
if not, perhaps the S2 is computer idle-controlled?
Old 08-26-2004, 07:56 PM
Send a message via AIM to bluebullet
nah if it doesnt close, the idle stays at 2000 rpm..my car used to do that until i found out the bracket was a little bent, causing the throttle to stay open...a little muscle and the car idles fine now
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 08-26-2004, 08:39 PM
kayw's Avatar
thanks for your guys kindly reply.
When the car is idle, does the throttle body fully closed or leave a little gap? It is closed when engine shut down. However, engine couldn't be started when I remove the air hose... so it is a mystery... to me
(I will look for any oddly screw when I back home -- since I am in the office now)
Thanks.
Old 08-26-2004, 08:59 PM
TCMdocs944's Avatar
Ni hao ma!
Your throttle may not be fully seated (sealed) when closed. Did you adjust this when the throttle was out of the car?
Good luck
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-27-2004, 05:54 AM
kayw's Avatar
I didn't adjust... just clearning as usual. Anyway, I am going to take it out again tomorrow and see anything wrong. If still fail, I shoot some photos and share with your guys. Hope it help! Thanks. Kay
Old 08-27-2004, 07:40 AM
TCMdocs944's Avatar
how be your llama.
Old 08-27-2004, 07:47 AM
TCMdocs944's Avatar
Kayw- I am thinking this is something simple...
Maybe a thread from the cleaning rag got stuck in the throttle opening or something.....Try this if you need more info
FR- GET BACK TO WORK......
shouldn't you be designing some rockets or something right now?
Old 08-27-2004, 07:54 AM
kayw's Avatar
Finally I fix the idle. There are 2 screws on the throttle switch. Slightly loose 2 screws to adjust the position of the throttle body until a "click" sound heard. I think the "click" sound is the position of idle speed position. The car runs good now. Thanks for all of you helping me!! Kay
Old 08-29-2004, 02:36 AM
