-   -   what size tires (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/179793-what-size-tires.html)
max29a 08-27-2004 08:36 AM
what size tires
I know we have just recently been over tire sizes, but I am a newbie and I did a search and couldn't get any clear idea on what I can put on my car.
I have an 85.5 944 with fuchs, can you tell me from that exactly what range of tires I can put on? I need some new tires.
I believe right now I have
225/50 R15 on the rear
and 205/50/15 on the front?
I admit I don't really understand tire sizing.
TCMdocs944 08-27-2004 08:45 AM
225 = width in mm's
50 = the ever mysterious aspect ratio (how tall the tire is compaired to width) the larger the number the taller the tire.
15 = that there be your wheel size in inches.
If your wheels are all the same width (probably so) than you could go up on the front size to equal the rear in the very least. I wouldn't go with anything more narrow
ie <205
What look or performance are you trying to acheive?
UconnTim97 08-27-2004 01:11 PM
I have the 16' Fuchs, I have 205 55 16s on the front and 225 50 16s on the rear. I just put on a new set of Dunlop Sport 5000s and they are great so far.
max29a 08-27-2004 03:49 PM
I am going for performance.. I don't autoX or anything (yet) so I would like something that won't break the budget too bad but will perform nice on the street.. hopefully less than $100 per tire.
thanks for the info
Don 944 LA 08-27-2004 08:07 PM
I have 225/50 R15 both front & rear , handles great
serge944 08-27-2004 09:15 PM
You can get yokohama es100's for about 80 a tire at tirerack. Cheap, and many praise them.
scottmandue 08-28-2004 07:14 AM
I made the mistake of NOT doing that and now I wish I had put 225's all the way around, got 225's rear and 215's front. Got a little bit of understear and can't rotate tires...
So Don, where do you park your car?;)
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
