-   -   Sensors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/179967-sensors.html)
frankzoolu 08-28-2004 01:09 PM
Sensors
Does anybody know how the sensors work that are located on the top of the bell housing? I believe they are called speed sensors. My car will not rev past 3000 rpm and I believe these to be the problem. Also the setscrew that goes in the flywheel has come out. Is there a way to put that back in without removing the bell housing? Could that screw be causing the problem?
Karl2bdc 08-28-2004 07:42 PM
If your car will not rev about 3k, your TPS is more than likely shot. Unplug it and rev it up....if it revs to full range, it is bad.
