headlights
I cannot get my high beams to work. When I turn my lights on they pop up on the first position of the switch, but they don't turn on until I go to the second position on the switch. Is the switch bad or are the high beams located somewhere different?
04 infiniti G35
Old 08-30-2004, 01:17 AM
High beams are activated by pulling straight back (towards you) on the turn signal lever. The first click on the button you're talking about is parking lights and activating the headlight motor, the second click turns on the low beams. Everything is working as it should, it sounds like.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 08-30-2004, 07:08 AM
Ornery Bastard
Turning on the parking lights should not raise the main headlights. At least, my 924S which uses the early 944 interior and wiring did not raise the headlights with the switch at the first position.
Aaron
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 08-30-2004, 10:35 AM
My mistake, I think you're right Aaron. I'm out of town so I was going by memory. The high beams, however, are definitely located on the turn signal switch.
Old 08-30-2004, 11:12 AM
Ornery Bastard
Yup. You're right about the high-beams being on the turn signal lever.
Just like they are on every modern car.
Aaron
Old 08-30-2004, 02:20 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
THis is how my headlights work - I have an '88 NA so might be different on an early
turn switch to 1st position - parking lights
2nd position - headlights pop up, low beam
pull directional stalk towards you - flashes high beam
push drectional stalk away from you - high beams on, stays pushed back
turn switch back to 1st position - parking lights, headlights stay up (handy for washing car)
turn switch off - all lights off, headlights go down
if you try to flash the high beams with the headlights down, the fog lights flash instead. would be handy for flash to pass, if anyone here knew what that meant.
nate
1988 944... and a bunch of other cars
Old 08-30-2004, 03:03 PM
Ornery Bastard
nate
The early cars are different.
They have a switch like a lightswitch.
First position: parking lights, headlights off and lowered.
Second: Low-beams on and raised.
Pull turn signal stalk towards you up to the resistance: Flash high-beams.
Pull turn signal stalk towards you past the resistance (there will be a 'click"): Turns high-beams on or off.
Return switch to first position: parking lights on, headlights stay raised.
Return switch to Off: All lights off, headlights lower.
Aaron
Old 08-30-2004, 06:20 PM
