rachwalj's Avatar
Update, broken balance shaft belt FIXED!!
In about 4 hours, here is what was accomplished..
I Used Conti belt(s) from Pelican...
Changed:
Balance shaft (was broken inside the cover)
Cam Belt (Definately on its last leg)
Lower Balance shaft roller
Balance shaft tensioner
Powersteering belt and tensioner
WHAT a difference that balance shaft belt makes!!!
I used the Kriket tool and took like 47 readings before I trusted it, but I am confident that it is the right tension. Now for the recheck at 2000..
Tip I would recommend to anyone who does this job...
GET THE 27mm Open-ended Wrench. This will save you a lot of time.
Also a second person makes all the difference.
SOLD 944 n/a. Searching for next endeavor...
Old 08-30-2004, 06:26 AM
Kriket tool
Stupid question but whats that?
1985/late 944
Old 08-30-2004, 07:42 PM
rachwalj's Avatar
This is the Kriket tool.
I spent 21 bucks on it and tested it on my wife's 4Runner fan belt. Took me a couple of tries, but after 5 minutes, you know exactly how to use it.
I have to re-tension my belts in 2000 miles, so I'll see how well I did.
Old 08-31-2004, 09:23 AM
