A/C blower switch only works on high speed
have a 89 S2. The blower switch just quit working on speeds 1-3 speed 4 the high speed setting works fine. Does not matter whether a/c switch is acitivated. What should I check first and where?
89 944 S2 Guards Red Mint
97 Harley Low Rider..wifes choice??
01 Ford 250 ..w/gas station addition
Old 08-30-2004, 01:06 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
it's a problem in the switch. You have to disassemble it and clean all the contact terminals OR get a new switch.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-30-2004, 02:20 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The blower switch does not normally fail.......
In the late models you have resistors by the blower in the engine compartment. ....... Check them for breaks or use an ohm meter for resistance....
They are kinda hidden.... but I think you will find them. Look for a white connector about 3-4 inches long with 2 screws holding it down on the plastic housing.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-30-2004, 02:42 PM
mine failed.
Old 08-30-2004, 02:44 PM
same problem in my 2000 Saturn, its the resistors more then not
1985/late 944
Old 08-30-2004, 07:33 PM
The resistor bank mounted on the blower housing has thermostats incorporated in it. As the years go by the therrmostats get gummed up. Clean the thermostats with carburetor cleaner.
The speed control contains a bank of resistors that get hot when in use. The thermostats prevent them from getting too hot and possibly melting wires or worse. The airflow of the blower maintains the temperature of the resistors and thermostat. Mine quit working except for speed 4 about a year ago. I discovered this by checking with an ohm meter after removing the switch.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-31-2004, 03:32 AM
Don 944 LA's Avatar
Kind of on subject ( trying not to highjack thread )
My AC blower ( under glovebox ) sounds like the blower is falling apart. Are ther any servicable parts or bearings to replace ??? or do I have to get a different assembly..
I only kick in the AC to run the second fan when I'm in traffic cuz my system still needs charged.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 08-31-2004, 08:44 AM
blower switch
Must just be a dirty switch, all fan speeds worked great today..thanks for the help.
Old 09-01-2004, 05:18 PM
