car wont start
1986 951 worked fine yesterday now wont start it has new reference and speed sensors in it. it is getting spark, the fuel pump is working and the fuel rail is getiing fuel i hooked up a wired to the injecters and they all work. if all of this is working why wont it start
Old 09-02-2004, 03:54 PM
i have tried that
Old 09-02-2004, 04:00 PM
with the car on i got 2.0 kohms and off i got 1.8kohms
Old 09-02-2004, 04:10 PM
i have pulled a spark plug wire and put a spark plug in it and saw spark
Old 09-02-2004, 04:23 PM
adida(r 944)'s Avatar
silly question how long ago was the reff and speed sensors installed?.... try pushing the connections together more and try again. may wiggled loose............................................. .......................................... i dont know.................... listen to wilky
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 09-02-2004, 08:00 PM
i bought a noid light today hooked it up and i am not getting any signal what would cause this
Old 09-03-2004, 12:51 PM
ae1969's Avatar
Send a message via ICQ to ae1969
What is the voltage on both pins at the injectors?
Wire breakage in the harnesses and connectors is a big problem on these cars..... If you have 12volts on both sides you have a short........ you should see 12 and 10
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-03-2004, 01:10 PM
ok tried all of them nothing if this is a failure of the dme can this transistor be fixed or am i looking at a new dme. the car does have chips in it could they be doing anything?
Old 09-03-2004, 01:11 PM
i have 12 and and 10 volts with the key on
Old 09-03-2004, 01:13 PM
i do not know anybody that i could borrow one from should i try replacing the chips with the stock ones
Old 09-03-2004, 01:25 PM
no access to an oscilloscope but yes my tack works and when im cranking the engine it reads about 200 to 300
Old 09-03-2004, 01:44 PM
ae1969's Avatar
I think you are right FR....
From what I have read the KLR does not affect injector firing
Also the main power transistors can develop cracks at the soldering joints.......so you may be able to re-solder to solve your problem..
Old 09-03-2004, 02:19 PM
i am not in that big off a hurry i bought the car a year ago and rebuilt the engine i just last week got the car running i only have 30 miles on it its not my only car is there any way that some other sensor would be telling it not to fire
Old 09-03-2004, 09:30 PM
my injecters are firing i got a noid light and they are working now i hooked up a fuel guage and im geting 35psi and it does not loose 14 psi over 20 mins. im getting spark but its not a nice blue one could this be my problem a bad coil maybe
Old 09-05-2004, 11:41 AM
i was being stupid the other day i had unplugged the computer when you told me to test one of the pins i never plugged it back up to test the injecters i pluuged it up and tried again they are firing but the car wont start
Old 09-07-2004, 01:10 PM
i hooked up my preasure guage i have 35 psi i took the spark plugas out and cleaned them up they were all black
Old 09-07-2004, 01:18 PM
do u think it will start then if i fix that
Old 09-07-2004, 01:52 PM
ill try that then thanks
Old 09-07-2004, 01:55 PM
i was just looking at a manual i have on cd its for a 944 turbo its says when testing fuel preasure you should get 2.3 to 2.7 bar when jumping the relay they didnt say to remove any vacumm line so if thats the case then my regulator is working right?
Old 09-08-2004, 11:02 AM
yes 2 bar is right at idle but my car wont start so i can only jump the relay when i crank the engine it is still at 35 psinow when im cranking should i only have 20 psi
Old 09-08-2004, 11:44 AM
