-   -   question for FR WILK. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/180915-question-fr-wilk.html)
bigyagi 09-03-2004 10:59 AM
i have no marks on my dme, or socket, to inform me which is pin #13. i want to check the eng temp sensor, but dont want to unplug at the eng side. from which end of the plug, do i count from?
seems my air temp sensor is no good also, as i'm getting a reading of 0.82k at 28c, when it should be between 1.45, and 3.3, at that temp!
regards, bob.
ae1969 09-03-2004 01:16 PM
FR do you have the descriptions of the pins that goes with that pic scanned..... This is a good reference for everyone.
If you want to check sensors IMO you should check the sensors at the dme connector ... this way you can rule out shorts and breaks as well.
I have chased to many shorts to assume its just the sensors...
bigyagi 09-04-2004 02:59 AM
thanks FRW ! once again your help is very much appreciated.
yes alex, i prefer to check at the dme end!
it seems that i'm overdue on some more electrical issues!!
regards, bob.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
