-   -   I have a 86 944 N/A with phone dials...what's my lug pattern? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/181119-i-have-86-944-n-phone-dials-whats-my-lug-pattern.html)
Makenzie71 09-04-2004 08:56 PM
Title says it...and it's a 47mm offset, right?
Macfreak007 09-04-2004 09:36 PM
if its an '86 its 23mm offset, thats the early offset, all cars before '87...
Makenzie71 09-04-2004 09:39 PM
So if I picked up a pair of early phone dials for the rear it'd bring them out 24mm on either side? That's fill the wheel well very nicely...
What about pattern?
(and thanx!)
speed 09-05-2004 07:40 AM
5x130mm
ae1969 09-05-2004 10:06 AM
Your 86 has early offset wheels. (23 mm)
A 47 mm offset wheel will retract 24 mm in towards the body of the car.
If you want to run late offset wheels you need a spacer.....
ender944 09-07-2004 08:05 AM
What size spacer?
TCMdocs944 09-07-2004 11:08 AM
Lug pattern the same for all Pcars from 944 on.
TCMdocs944 09-07-2004 11:17 AM
You will need spacer to make them look right. Spacer size can be a matter of preference as well. 24mm will bring it out to stock BUT.........If you are spacing you might think about going bigger.
if you go up to 2" (or 2.5) rear (not sure of the front) the tires will come out in the wheel well and you can run even later offset wheels in the future.
Just a thought.
TCMdocs944 09-07-2004 11:23 AM
Danno's site....just look for the wheel faq
Makenzie71 09-07-2004 12:17 PM
thanks guys...I was just looking at wheel options trying to find a way to ake my rear wheels fill the rear wells like my fronts do...
