Send a message via AIM to TurboFoFo
Oil Pressure Sender
Hey all, how do I tighten the 2 leads on teh oil pressure sender? one is very tight and the other is pretty loose but I can't figure out how to make it tighter. Am I supposed to tighten the tiny little screw on the end? Cuz if tha'ts what has to be done, what kinda tool you use for that? it's tiny!
PCA Member
86 951 Blk/Blk
Guru Chips, Momo MonteCarlo Wheel, Kinesis 17" SuperCups
Old 09-04-2004, 11:09 PM
chapstic2001's Avatar
Send a message via AIM to chapstic2001
It is either a 7MM or 8MM nut. Just take a nut driver or ratchet and tighten it up. There should also be a lock washer there to prevent the nut from backing out.
'08 BMW e90 335i 6MT stock [aka 'take two']
'12 Dodge Durango [family hauler]
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage]
Old 09-05-2004, 04:05 AM
thanks buddy, thats all i needed to know.
PCA Member
86 951 Blk/Blk
Old 09-05-2004, 10:34 AM
DumasDemon84's Avatar
Where is the oil pressure sender located at? Was your gauge light coming on but needle pressure showed ok? I'm having this problem. Thanks.
1986 Guards Red 944 Auto
1995 Chevy Tahoe 3-3 drop, w/ 22's
2006 GMC Envoy
1989 Dodge Shortbed(project)
Old 09-05-2004, 10:49 AM
The oil pressure sending unit is located under the oil filter. you can access it from under the car. Just lift the passenger side up (use jack stands or else you'll die) *wink* *wink* and crawl under near the oil pan. You should see two little wires connected to it.
Oh and my problem was it was just pegged at 5 all the time
PCA Member
86 951 Blk/Blk
Old 09-05-2004, 11:03 AM
Thank you very much! I'm going to garage right now(jackstands in hand). I will be back later.
2006 GMC Envoy
Old 09-05-2004, 11:06 AM
My gauge doesn't work all the time.. it will stay at zero, sometimes if I tap on the cluster it will go back up, but the next time i start the car it won't work again, and tapping on it doesn't always work.
All the connections on the back of the cluster are good, could this be a sender problem? I'm thinking not because tapping on the cluster "fixes" it..
Old 09-05-2004, 03:49 PM
gtroth's Avatar
You can get at it pretty good if you drive the front of the car up on Rhino ramps too. I place jack stands under the frame anyway, just for good measure...
1995 993C4 guards red
1988 944S alpine white
Old 09-05-2004, 06:41 PM
