ilikemy944's Avatar
Send a message via AIM to ilikemy944
Angry Should I light it on fire now, or 10 min. from now?
So I buy nice new 55lb injectors and all the good stuff cause I had a spraying bad injector. I get all the new stuff in, start the car, and it dies right off, when trying to idle... Any guesses why? Oh, no fuel pressure.
THERE IS A FREAKING HOLE in the METAL PIECE of the fuel hose going to the FPR.
A HOLE. How does a hole get into such an object? I have no idea. Its a big hole too. Gas pretty much pours out of it. Why didn't Porsche make that hose detachable at the point it enters the engine bay? That would make sense in a situation like this. PET shows that the hose is detachable. So either that is an update or someone forgot to actually look under the hood.
BAH!
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 09-05-2004, 05:55 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You know.......that sucks
Well ....... its time for steel braided lines....
Be happy it just completely failed as opposed to a slow leak..... read = engine fire.
Someday it will run Brad.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-05-2004, 06:21 PM
ilikemy944's Avatar
You have no idea how pissed off I am.
I'm about to start pulling the hose off the n/a
Brad Tompkins
Old 09-05-2004, 06:25 PM
ilikemy944's Avatar
Apparently the hole is supposed to be there. Its just supposed to have a plug in it.
BTW, this freaking hose is ONE piece, all the way to the fuel filter... I'd have to drop rear suspension to replace it, if I didn't do the cut and replace with SS hoses thing.
Brad Tompkins
Old 09-05-2004, 06:50 PM
AFJuvat's Avatar
You poor ba$tard.
Unless your line has been updated to the new three piece line - that line goes all the way to the fuel tank.
can you say drop the rear suspension?
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-05-2004, 09:33 PM
AFJuvat's Avatar
Let me rephrase.
Look under the passenger side of teh car - about equal with the door. If you have a large connector that is shaped like a nut joining two lines together, you are golded - can replace it in an hour and a half.
If you don't, the poor ba$tard applies.
AFJuvat
Old 09-05-2004, 09:45 PM
ilikemy944's Avatar
<-- poor bastard
BUT
I have a new piece of hose that I am going to make work instead
Fuel injection line and the associated clamps for that line. I'm just going to chop it off and make my own.
Brad Tompkins
Old 09-06-2004, 10:21 AM
