Unhappy please heelp my civic
please help me about three weeks ago is was driving normally when all of a sudden my volts on my volt meter read 12.01, when i let up on the gas the volts went back up to 14.03. when i turn on the fan or head lights then the voltage goes back up to 14.
now when i first start the car it's fine for about 5 or 6 miles and then it will fall down to 12. volts or lower. after this problem i immedentaly chanced the battery with an optima yellow top, but still no luck. then i changed the altenator with a 96 amp altenator when the stock is 70 amp, still no luck. then i changed the gauge to an autometer digital voltmeter, and that still didn't solve the problem. i'm thinking that maybee the belts are slipping. when i had the altenator installed he said all three belts look worn and dry rotted. please help my 95 civic '
p.s. thanks
Old 09-26-2004, 08:30 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
ummm... i think you are in the wrong forum....
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-26-2004, 08:32 PM
Ornery Bastard
You put an overly expsnsive battery (Interstate's batteries are just fine, no need to spend double on an Optima unless you have issues with conditions in the engine compartment causing other batteries to leak) in your car to fix a voltage problem without checking the voltage across the terminals with a hand-held multi-meter?
You put an expensive aftermarket alternator on (which will NOT increase voltage, only amperage) without checking the draw on the stock alternator?
You knew you had old and dry-rotted belts and didn't change them?
Please take your car back to the dealer and tell them that you're not sufficiently qualified to own it. No car deserves that kind of treatment. Also, fire whatever mechanic performed these services. Any good mechanic would have trouble-shot the problem first instead of throwing parts at it. That guy should not be in business.
For more constructive advice, where in the electrical harness is the voltage guage wired? It needs to be reading pretty much directly across the battery terminals, if you have spliced it into the electrical system at just any random point, it will never give you an accurate reading. Period.
Aaron
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 09-26-2004, 09:20 PM
Re: please heelp my civic
Originally posted by FR Wilk
Honda Civic Repair Kit
Add to a full tank of gas!
LOL
Old 09-26-2004, 09:22 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Normal civic owners don't work on their cars...so when I was in one, I couldn't go to civic forums and expect real help. I went to the FC/B RX7Club forums and the MKII/III Supraforums and asked. Much like here...those people WORKED on cars and knew what the hell was up.
Last time I asked a legit question on a honda forum I was told that my filter wasn't big enough and that I needed to get a CAI.
(question was 5k engine cut)
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 09-26-2004, 10:40 PM
what was the answer?
btw, i owned a civic and worked on it myself.... but i never even thought of going to one of their forums because of what you just despribed. but it should be asked in the lounge.
Old 09-26-2004, 11:51 PM
Faulty cold solder point in the ECU. After 5k, no signal went to the injectors.
Old 09-26-2004, 11:55 PM
adrian jaye's Avatar
sounds like the car is totally trasched, Honda put on a service advice about this fault, basically they say after this fault the car is a write-off
so now you need to buy a porsche
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 09-27-2004, 01:04 AM
TCMdocs944's Avatar
Sell Civic
Buy Porsche
Or you could try posting your question here
Civic Friendly Forum
These guys are much better at questions like this
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-27-2004, 09:15 AM
Originally posted by TCMdocs944
Sell Civic
Buy Porsche
hahahahahahah ROFLMAO
rennlist
hahahahahahahahahahahaha
NotJustPorsche
Old 09-27-2004, 09:25 AM
TSNAPCRACKLEPOP's Avatar
yes, the belts are slipping, but i would pour a little more cash in it before i tightened them up.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 09-27-2004, 09:38 AM
TCMdocs944's Avatar
Just trying to be helpful.
You could try here as well.....Ask for KurtV
Very heavy traffic import racer forum
Old 09-27-2004, 09:42 AM
Yeah, I'd put a bigger stereo in it and some of those ghetto tires that stick 8" outside the fender wells.
But whatever you do, DON'T try tightening the belts. And never replace them if they're dry rotted.
And please, please DON'T buy a Porsche!
Old 09-27-2004, 05:31 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
i think that might have been a joke post... although I admit that I don't get the joke...
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 09-27-2004, 07:03 PM
Send a message via AIM to Trevor
Man, and you guys say the 911 guys are snobs. A totally misplaced post though with an obvious answer? Troll?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 09-27-2004, 10:11 PM
TCMdocs944's Avatar
Had to be a troll....wasn't it obvious....
Someone replaces the whole electical system when their belts are 'dry rotted'. Then answers their own question at the bottom of the post?!
YOU GUYS HAVE TO DO ALOT BETTER THAN THAT!
(must have been a new troll, no serious kills under his belt yet)
Old 09-28-2004, 07:31 AM
you know i put new belts and that still didn't solve the problem.
i tried honda forums, and all forums for that matter but i thought i'd try the porche forums because porches are harder to work on.
i didn't think that i would have a bunch of jackass's responding, i just needed a little help. if you want to leave a helpful responce
then go ahead, but if not, your mom should have swallowed
Old 10-09-2004, 07:28 PM
Writer/Teacher
CJFusco's Avatar
just because Porsches are more expensive does NOT mean they are harder to work on. My 944 is the easiest-to-work-on post-1970s car I have worked on.
Old 10-09-2004, 09:13 PM
Yeah, now thats going to get a ton of people to help you. Take it to a REAL mechanic.
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Ornery Bastard
Belt tension?
And I'm sorry, but you're still an idiot for not trouble-shooting this before you threw parts at it.
I ask again, how is your voltage guage wired in? The location at which it taps into the electrical system is absolutely critical. If you just spliced it into any old live 12v lead, then chances are that all the odd readings are simply because of an inept installation.
It needs to be on a clean lead, as close to the battery as possible. In an ideal world, it would run directly across the battery terminals.
Aaron
Old 10-09-2004, 09:49 PM
