White smoke at redline
OK a couple times coming outta the gate I've noticed white smoke at the redline and usually kicks out a nice cloud of white smoke but then goes away. Its only present under hard acceleration and when I take her to her limits at the redlne usually in 2nd or 3rd gear. It doesnt stay white and when I let up on her to normal cruise speeds its gone but still has me asking if this is a normal thing. Your thoughts am I kicking carbon out or something or is this just normal.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 09-27-2004, 04:21 PM
Doesn't white smoke indicate burning coolant? Someone correct me if im wrong.
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 09-27-2004, 05:07 PM
TCMdocs944's Avatar
Has the head gasket ever been changed in that car?
Sounds as if a little coolant could be breaking through when you push it.
Take a look at what I found when I fixed my valves. Mind you, this car had been well cared for most of its life.
Looky Looky
You could always listen to "old country Doctor" advise - if it smokes when you redline it, dont redline it anymore
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-27-2004, 06:02 PM
winter-hater club member
nynor's Avatar
possibly oil blowby.
"COOL PRIUS!" - Nobody Ever
Old 09-28-2004, 02:17 PM
oil blow by whats that
Old 09-28-2004, 03:59 PM
nynor's Avatar
ok, i am probably talking out my a$$, but here goes:
it is my understanding that as your motor is turning, it creates pressure inside the crankcase from the movement of parts, the rotation of the crank, and, if your rings are bad, excessive gases entering the crankcase from the cylinders. also, there will be some oil misted/vaporized in the crank. then, if the rings are bad, the pressure then comes back into the cylinders and gets burned, making white smoke. plus, i think the rings are less efficient at scraping the oil from the cylinder walls at high RPM's. like i said i am not an expert (please don't flame me!)
Old 09-29-2004, 08:44 AM
TCMdocs944's Avatar
Doesnt oil usually show as black smoke, not white.?
Old 09-29-2004, 08:50 AM
nynor's Avatar
no. oil will show as white/blue. black means that the mixture is too rich.
Old 09-29-2004, 09:14 AM
flangermog's Avatar
Just my two bits, the problem you're having is that you get white smoke out the back of a (almost) 20 year old car when you redline it?
Answer: don't redline it! It's red for a reason you know!
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 09-30-2004, 02:57 AM
Echo the last statement.
Patient: Doc, it hurts when I do this...
Doc: Then don't do it!!
Bob S. former owner of a 1984 silver 944
Old 09-30-2004, 01:17 PM
Noted...i was under the impression that these cars were made for said abuse...
Old 10-01-2004, 03:57 PM
chitown944:
When you say redline, is it possible that you are hitting the rev-limiter? If so, that will cause a puff of smoke......just a thought...
Old 10-02-2004, 06:55 AM
nynor's Avatar
ahhh... that could be. rev limiter kicks in, no spark, but there is still fuel in the system... any thoughts?
Old 10-02-2004, 09:59 AM
no limiter on her...has a chip in it and i can actually take her past the redline...please dont flame me....just wanted to see what her limits are...ill try and control myself
Old 10-02-2004, 08:54 PM
TCMdocs944's Avatar
No flames but redline isn't really a big factor in this car.
powerband from 3-5 grand...give or take
Higher than that and you are getting diminishing returns yes?
Maybe shifting a bit higher would bring you more 'into' the powerband of the next gear?
All in all it sounds like you probably just have and old headgasket...not really a problem until it starts happening other times.
Old 10-04-2004, 03:33 PM
