The Chris's Avatar
Porsche Crest Need some 968 shopping advice...
Hey all,
I'm looking to get a 968 in the spring (coupe, manual transmission), and I wanted to get your guys opinions on what to look for. This would be my first Porsche, as I've had Toyota's and Nissan's in the past.
What kind of mileage should I consider? I would like to keep the price under $20k if possible, but I would be willing to go a little higher if that's unrealistic.
How expensive would it be to maintain? I do most of the work on my Maxima, so I was wondering if the 968 is easy to work on (assuming you know your way around a car).
This is my "base" car right now...it has everything I want, but has a tip-tronic:
http://www.raycoeuro.com/html/95Porsche968CoupeBlack/car.html
Think that one is a good price?
Oh, and how's the aftermarket support?
Thanks for your help!
Old 09-27-2004, 08:00 PM
Blackfoot's Avatar
'95+ M3
_______________________
Cars
Old 09-27-2004, 09:08 PM
That car is way overpriced given 1) miles and 2) tiptronics. Browse through the "Buyers Guide" in the forum over at 968.net and you'll start developing a good feel for this market.
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car
'88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R
Former cars: '94 Black 968 Cab "Steffi" (totaled) '87 Nautic Blue 944 S3 "Emma" (blown motor) ; '90 White 944S2 ; parts cars
Old 09-27-2004, 11:03 PM
Way overpriced indeed. For reference, my girlfriend got her '92 last year for 15K, one owner with 55K miles, all maintenance done. Read up on the pinion bearing, that is the one big thing to worry about other than the usual 944 stuff. 20K should get you a near concourse example.
'86 Guards NA 70K- driving 11yrs
'98 Techno-Violet M3 57K- since 4/04
'55 MiG-15 UTI - Mach.97 -rebuilding
'58 Cessna 175 w/GO-300
'98 Scarab Sprint, 4.3V, 62mph
'92 Guards 968 (my girlfriend's)
Gone...
'82 Camaro Z28 1st car
'84 VW Rabbit Cabrio & GTI
'77 BMW 630 4spd sport bilstiens
'84 POS Cavalier- drove to junk yard
Old 09-28-2004, 06:52 AM
The Chris's Avatar
Ok thanks guys.
Any other common problems I should keep an eye open for?
Old 09-28-2004, 07:29 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Just timing belt, really
Maintanence records are a must.
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 09-28-2004, 08:52 AM
Pinion bearing is one of the more common problems. Affecting maybe 10% of cars. It usually shows up early (less than 50K miles), but can show up at any time. The only way to tell, is when the transmission starts making noise. There's no way to check, short of diassembling the entire transmission.
The other big 968 issue, is Variocam mechanism inspection. There is a chain and plastic wear-pads inside the valve cover that wear. Based on what i know about 968's, the wear of both parts seems highly dependent on quality of oil used and frequency of changes. This mechanism should be regularly inspected starting at around 60K, and inspected every 15K miles. It's not a difficult or expensive inspection to do, just requires removal of the valve cover, and a dental mirror. Inspection intervals are at your descretion based on condition observed during the first inspection. Neither pads, nor chain is expensive, but a failure will produce heavy collateral damage (many bent valves and possibly damaged pistons, which are all very expensive!)
As CJ said, Timing belts are an issue with the 944/968 series of car. Replacement at shorter intervals than most other cars is required. Factory reccomended replacement interval for the 968 is 45K miles. Most people replace them every 30K, since a failure, again, will produce heavy collateral damage. If you work on your own cars, the belts are not expensive, or terribly difficult to change. The 968, unlike the 944 does NOT require the very expensive factory belt tension measuring tool to be used, since it has an automatic, hydraulic belt tensioner.
Overall, i have found the 968's to be pretty reliable, and alot of fun. 968.net is the best place to go for specific questions.
Mike
'92 968
'01 VW Jetta TDi
Old 09-28-2004, 09:43 AM
