friendlyguy64's Avatar
project 87 924S into a 951 turbo?
I want to build a project car.Basically I want to turn my 87 924S into a turbo.If I can take the parts off of a 951 can I just bolt them on.I know i need a left engine mount to bolt on the turbo.Can a 951 intake manifold fit on my car?the olny difference between the 944,924S, and the 951 are the heads and the lower compression from th 951.Has anyone ever tried this project.Should I ?Dont just tell me not to waste my money and buy a 951 the defeats the purpose of the project.Any comments?
Old 09-28-2004, 08:27 AM
TCMdocs944's Avatar
This has been done and covered in many, many posts..plus and minus.
You seem like you really want a "project" though and not just an end result.
So, what end result would you like to get? Are you going for speed? Are you going for performance? Just to do it? Resale value (none)?
To answer your questions simply, no. It is not a straight bolt-on. There will be lots of hair pulling and some fabrication.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-28-2004, 08:41 AM
what further mods i would still use the dme that comes stock, i know soem guys that help me out by that.Can you give me the post that did this transformation.Im going for speed.What fabrications?will the 951 inatke manifold fit?
Old 09-28-2004, 08:48 AM
jm951's Avatar
Best way is to get a wrecked 951, transfer parts. Don't try to mix n match engine parts. Good luck, this has been hashed over many, many times.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 09-28-2004, 08:51 AM
fast924S's Avatar
Send a message via AIM to fast924S
Yea, you will need a smashed 951 to use the parts from, You will need to pull your 924S engine and swap the 951 engine in. The 951 enigne is made for the turbo, stonger parts, lower comp ratio, ceramic linings, different head, and I think it has different valves too. Also you will need to swap DME's and the 951's turbo dme too, You will also need all the exhaust parts, and fuel system parts, For the most part, take everything out of the 924S and put everything from the 951 in and then figure out how to wire it.
If your looking for a good project I would stay away from swapping the 951 into a 924S. IF your intrested I would try one of the 3 things
1. Supercharge your 924S engine, alot easier and alot of fun and you can play with boost and keep your 924S engine or,
http://www.speedforceracing.com/productsporsche_superchargers_944v8.php
2. A low boost custom turbo setup on your 924S, In low boost I mean like 6-9psi, Find a turbo and make the pipes to make it work, then figure out how to get the fuel and timming right and keep egt's down. Again you get to keep your stock engine
3. V8 conversion, If you looking for tons of power then drop in a 350 and turn your Porsche into a hybrid.
http://www.renegadehybrids.com/944.htm
Also here are some other sites to check out for performance parts and info
1. http://www.lindseyracing.com
2. http://www.autothority.com/
3. http://www.broadfootracing.com/
4. http://www.gururacing.net/
5. http://www.jmengines.com/index.htm
6. http://www.ebsracing.com/water.html
7. http://www.easy2useweb.com/Sites/381/default.asp?PageID=3540
8. http://www.weissach.net/Suppliers_924-944-968.html
Ohh yea and check out this guys ride too
http://gallery.rennlist.com/gallery/albuo93?page=1
If you wanna talk about your 924S just E-mail meIm a happy owner of a 87 924S that is getting alot of work done
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-28-2004, 06:42 PM
thanks for all of the ideas I just want to make my porsche fast.If you give me i deas that would be great.like headers, exhuast,powerchips,what else?I was going to hook up nitrous to it.that would be awsome.the supercharger kit come sout to like $6k.I aske dhim to send me evrything that includes the kit and most of it comes from a 944 turbi like the intercooler and the injectors etc.I wish i can just find the c2 procharger bc he just wants 2500 for that alone.any other comments
Old 09-28-2004, 07:03 PM
fast924S's Avatar
OK well, First make sure everything is right and working with your car.
some things you can do to your NA are
1. header
2. full exhaust
3. MAF upgrade
4. chip
5. Cam
6. ignition upgrade.
theses six things are just about all you can do to the NA with out spending alot of $$$$$$, With theses mods you will notice a difference but its no supercharger. If you wanna start spending big money you can start rebuilding the engine with performace mods like
1. Race prep head
2. Fully worked crank
3 Raise the CR
4 Get everything lightened and balanced
5 Full port and polish
The thing you will learn fast about your NA is that if you want power from her you need to spend alot of $$$$$$ nothing is really cheap when it comes to getting HP in a Porsche.
As far as the nitrous goes, I love the stuff and will be installing a Zex 50hp dry shot on my 924S, But do yourself a favor before you do this, LEARN EVERYTHING AND ANYTHING ABOUT NITROUS before you start to play with it. Nitrous done wrong can be a very bad thing, but when done right its cheap power, The line is very thin.
Other then that the only way to get big HP numbers is Forced induction.
Old 09-28-2004, 07:19 PM
I don't think you want to make it fast. It already is. You want to make it QUICK!
Good luck & enjoy.
Sebastian
Old 09-28-2004, 07:26 PM
well i had a acura rsx with nos.it was pretty good for the cheap and easy way for getting power.doe szex make a specific kit for the 924s?
Old 09-28-2004, 07:49 PM
how fast does the 924s do a quarter mile stock?
Old 09-28-2004, 07:52 PM
fast924S's Avatar
The 924S I think is ike 14.2 seconds
Old 09-28-2004, 08:17 PM
Custom User Title
rammstein's Avatar
Ummm... that seems a bit over-exaggerated
Old 09-28-2004, 09:13 PM
so how fsat does it really go?
Old 09-29-2004, 06:07 AM
jm951's Avatar
1/4 miles stuff is like automotive T ball. If the ricers and the 'stang guys want to play there, let'em, a road course is where your car will shine. Better to spend your money on DE and become a better driver first. You'll find your car is capable of more than you are.
Old 09-29-2004, 07:13 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
stock 1/4 mile for a 924S is about 15.9 if i remember the ROAD AND TRACK test correctly... exact same as the 83-85.1 944.
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 09-29-2004, 07:20 AM
entertaining the idea
UconnTim97's Avatar
LMAO...that is great
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 09-29-2004, 07:33 AM
well Ive decided to sell my car.should I look for a 944 turbo or an s2
Old 09-29-2004, 07:37 AM
TCMdocs944's Avatar
If you are looking for 1/4 miles neither. Get a CRX, V8 it and be done.
If you like performance mods go with the Turbo. You can spend hours and thousands on that one. European Car magazine is about halfway through their black 951 project car. Big$$$ and Big performance.
Before you get started with Porsches.....You know how much parts cost right? I'm talking aftermarket, not dealer....
Example - Distributor cap and rotor $45 - 80 smackers.
Old 09-29-2004, 08:48 AM
tobster1911's Avatar
That is stupid. That is what people who know they will loose say to keep thier pride. Just make fun of something because you are not the best at it. If your point would have been that the 924/944 is not designed to compete in this area that would be a different matter. Just because you do not personally care for it does not mean it is not fun or challenging. It is not so very simple as you would lead us to believe. If you don't think that it take talent to keep that much horsepower on a strait line, vs. the awsome talent to take a corner at 30mph, then you are an idiot.
Sorry but I am in a bad mood already. I hate seeing stupid things with no proof to back them.
'97 Saturn SL (tiny 1.9L bubble car)
'98 Grand Prix GTP (4dr family car with a bite FOR SALE)
'87 944S (Sold as a German engineerd money pit)
'78 Chevy 4x4 (What I drive when everything else is broke)
Old 09-29-2004, 09:04 AM
