Send a message via AIM to drfatz
3.0 L crank in a 2.5 L engine?
I was wondering if its possible to install a 3.0 Lt crankshaft in a 2.5 Lt engine? I have heard that it can be done, but what needs to be changed and what is the end displacement?
Cheers
Graham
Old 10-02-2004, 03:52 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You would end up with a 2.7 as I recall.
Exactly what porsche used to make their 2.7.
but a 3L crank will set you back a minimun of $1,000
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-02-2004, 04:32 PM
umm...the 2.7L has the 2.5 crank but 104mm pistons
Tom
Early '85 944
Old 10-02-2004, 04:51 PM
Ornery Bastard
No, the 2.7 liter has a 104mm STROKE, not bore. The bore is the same as the 2.5 litre cars at 78.9mm.
The 3.0 has a 104mm stroke with an 87.8 mm bore.
The 3.0 is essentially a bored out 2.7, though I'm not entirely sure that the bore center spacing is the same.
Aaron
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 10-02-2004, 11:07 PM
are we talking about the '89 944 2.7L ?
3.0L have 87.8 mm Stroke
Tom
Early '85 944
Old 10-03-2004, 04:25 AM
What kind of performance gain can you expect from all that work? Seems like us 944 owners are constantly searching for the "holy grail" of speed.. I have been caught up in that myself..But now that I'm seeing boxsters with 11K on the odometer for 25K I'm begining to think it might be better to just buy one and ditch my 44...
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 10-03-2004, 06:00 AM
Aaron
Bzzzzt!
Wrong answer...
The 3.0 L engine and the 2.7 L (89 944NA) share the same 104 mm bore. The 3.0 has the longer stroke. The 2.7 shares the same crankshaft as the 2.5 L, and, consequently, the shorter stroke.
The bore center spacing is the same for the 104 mm bore and the 100 mm bore.
You could look it up!
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 10-03-2004, 06:40 AM
Ornery Bastard
Originally posted by 944 Ecology
Bzzzzt!
Wrong answer...
gb
I did look it up. But I see where I got it wrong, the site I looked it up on lists the dimensions as "Stroke/Bore" instead of the usual "Bore/Stroke". I should have been coherent enough to realise that these engines couldn't be that undersquare, but everyone has his off days.
http://www.petting-zoo.net/~gkm/944.html
Quick question now, will a 3 litre crank drop into a 2.7 litre engine? I realise that going from a 2.7 litre 8v engine to the 3.0 crank would not yield as much power gain as a true 3.0 since you wouldn't also get the 16v heads, but would that grank swap be do-able without major modification?
Aaron
Old 10-03-2004, 08:57 AM
Yes, you can put a 3L crank in a 2.7L 89 NA, but you will also need (at a minimum) new pistons and connecting rods...
This should result in your having a 3L 8V NA motor... I would estimate the power to be about 180-190, depending on compression ratio...
gb
www.944ecology.com
Old 10-03-2004, 09:09 AM
So then the answer to my original question about putting the 3 Lt crank in a 1985 1/2 2.5 Lt block is......? So it can't be done without changing the pistons and rods? Is it possible to bore it out, change the crank, pistons and rods and make it a NA 3.0 Lt 8v?
Old 10-03-2004, 09:45 AM
I don't believe that you will be able to bore the 100 mm cylinder out to 104 mm without compromising the strength of the cylinder walls.
Of course, that may not stop you from trying... You would be the first person I know of to do it.
YMMV
gb
www.944ecology.com
Old 10-03-2004, 10:41 AM
fast924S's Avatar
Send a message via AIM to fast924S
Use the search key man!!!!!!!!, A few weeks ago this was all over the forum. First a 3.0L crank is like 1500 used, SO its alot of money for approx 20hp. After getting rods the price will be up there. Also If I where you I would not stroke the engine, stroking increase pistons speeds wich can be very bad. If you wanna play like that then do what ferrari does, big bores small strokes= high rev, good power. If your gonna bore it out you need to have steel sleeves pressed into the cyclinders and then bore them out, It all can be done but its alot of money and labor. Your better off just buying a full 3.0L or 2.7L engine and droping it into your 944
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-03-2004, 11:37 AM
Send a message via AIM to SlowToady
As FRWilk pointed out in another thread about this, you have 4mm more travel in each direction (hence the new pistons and con-rods), but would you have to get the 3.0 oil pan as well or will the 2.5 unit work?
I, for one, would like to build a 3.0..or drop one in, but then you need the wiring harness, too.
On a releated side note, does anyone know if you can get aftermarket pistons coated with that AuSl(?) stuff that the factory units are coated with? I'd like a set of lighter, higher compression pistons...
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 10-03-2004, 03:08 PM
The short answer is yes, you can use a 3.0L crank in a 2.5L motor. What you will end up with is a 2.8L motor. This is exactly what Powerhaus ( http://www.powerhaus.com/ ) uses for their 2.8L conversion.
Old 10-03-2004, 03:10 PM
fast924S's Avatar
I have been looking and it is very hard and alot of money to find pistons aftermarket pistons that have a higher CR and that are coated, most will drop in a set of EURO pistons or drop in steel sleeves and get a set of sweet JE pistons.
http://www.importperformanceparts.net/imports/pek-porsche.html
http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944PISTONPISTONS
Old 10-03-2004, 08:42 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
so are you folks saying that all you need to bring a 944 2.5 up to 2.8 liters is install a crankshaft from the S2?
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 10-03-2004, 09:07 PM
fast924S's Avatar
No, you need to install a 3.0 crank, and get different pistons/connection rods
Old 10-03-2004, 09:10 PM
Comeau Racing
Wow! There's a whole bunch of crap info flying around in here! ...some of which got straightened out. Thanks for the effort you guys.
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 02-04-2013, 07:44 PM
Originally Posted by 944 Ecology View Post
Bzzzzt!
Wrong answer...
gb
So, in theory, you could fit a 3 litre block with the 2.7 litre 8v head to make a 3 litre 8v?
Why would anyone want to do this? Because the regs in the race series I race in preclude me having a 16v engine in a car that was originally 8v (in this case a 924S)
Old 10-12-2015, 03:31 AM
Amatuer Hour Specialist
Wellwood's Avatar
3.0 liter crank in a 2.5 liter block, with offset grinds...and a little more work.
Refresh951** l** Porsche 944** l** Porsche 951** l** Shawn Deal
Old 10-12-2015, 07:05 AM
