how do I take off the gears on the front?
sorry for not knowing the technical term but I need to take off the plastic part so I can replace the tensioner... is there a special tool I need to do this?
Old 10-03-2004, 07:51 PM
fast924S's Avatar
Send a message via AIM to fast924S
Wow nice engine, That sucks that the bracket is like that, MY AC bracket is like that and I need to remove it, Im not sure about what plastic gears you mean, You need to un bolt all the pullies and gears some you may need a puller and some PB blaster, then remove the rear timming cover
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-03-2004, 08:48 PM
cool, so if I go to auto zone what tool should I ask for to hold the gear still while I try to unbolt it?
Old 10-03-2004, 08:49 PM
hey your not TOO far from me... did you read my post asking for people to help me put the motor in the car? do you have that kind of expertiece?
Old 10-03-2004, 08:51 PM
fast924S's Avatar
I did mine
Yea but isnt middle town MA far away from CT?? I rebuilt my 87 924S engine 6 years ago when I was 16 here are some pics
Old 10-03-2004, 09:01 PM
fast924S's Avatar
I cant find a pic or remember the tools name, Let me do some searching and see if I can find it
Old 10-03-2004, 09:02 PM
fast924S's Avatar
CHeck out this link, Very helpful
http://www.clarks-garage.com/
also here is a list of tools neded from clarks site
Tool
Used For
Supplier
Part Number
Sockets
8mm Cheesehead (also called Triple Square and 12 point internal)
Pressure Plate to Flywheel bolts / CV Joint bolts
Snap-On
Lisle
FTSM8E
10mm Cheesehead
Camshaft sprocket bolt
Snap-On
Lisle
FTSM10E
12mm Cheesehead
Flywheel to crankshaft bolts
Snap-On
Lisle
STSM12E
6mm Long Allen Head
Cam Housing / Intake Manifold
Snap-On
FAML6E
6mm Long Allen Ball Head
Intake Manifold / Turbocharger mounting bolts
Snap-On
FABLM6E
5mm Long Allen Ball
Head
Throttle body / Turbo Air Filter Housing
Snap-On
FABLM5E
8mm Allen Head
Cam Housing Plugs
Snap-On
FAM8E or
FAML8E
15/16" or 24mm medium / deep(Optimum Overall length is 2 to 2-1/4")
Crankshaft Pulley bolt
Wrenches
15/16" or 24 mm open end bent thin head*
Timing and balance belt eccentric rollers
Baum Tool
T9A-24B
1-1/16" or 27 mm open end bent thin head*
Baum Tool
T9A-27B
15/16" or 24 mm open end (Modified 6" long, thin head)
Oil Pressure Sending Unit
1-1/4" or 32mm open end
Oil Cooler Lines (Turbo)
Craftsman
Snap-On
Other Tools
Belt Tensioning Tool
Timing (pre-'87), Balance (All), Alternator, Power Steering Belts
Sonnen
Baum
00-721-920-10
P 9201
Balance Shaft Pin Spanner
Removing Balance Shaft Sprockets
Sonnen
Baum
000-721-920-00
P 9200
Old 10-03-2004, 09:07 PM
your probabally about 2 hours away... you put the motor in yourself and got it all running and everything?
Old 10-03-2004, 09:24 PM
fast924S's Avatar
Yea its not to bad, It looks like you are more then half way done with yours, what are you having problems with
Old 10-03-2004, 09:30 PM
well deal is I bought the car and the motor was stripped down to the block but the guy I got it off gave up on trying to remove it... so I've got the old motor out and I've got the new motor ready to go (except for that arm on the front shown in the pic) and I pretty much need someone to help me put it in and hook everything up and get it running... this is my first porsche so I'm a little nervous about the whole thing... I THINK I got the bellhousing on the new motor fine but I'm not sure and I dont know how to tell... I just wish someone could get here and we could get it done together.
Old 10-03-2004, 09:43 PM
fast924S's Avatar
I would love to come and help but things are kinda crazy right now. I will gladly help you with what ever I can. E-mail me with some questions or just post them here and I will see If I can help you. One question for you is, Wich way did you pull the motor?? From the top or bottom??
Old 10-03-2004, 10:28 PM
well... I took out the 4 bolts from the cross member then I dropped it a few inches and then was able to pull it out the top.
Old 10-04-2004, 04:43 AM
fast924S's Avatar
Ohh Ok, See when I did it I dropped it out the bottom its a little different. SO I think You should be able to drop the new one back in no problem, then just start bolting things up
Old 10-04-2004, 02:01 PM
so... when putting the bellhousing back on do I just slap the 3 pieces back on? or do I have to line anything up first?
Old 10-04-2004, 04:04 PM
fast924S's Avatar
3 peaces??? do you mean the clutch, pressure plate and flywheel??
Old 10-04-2004, 04:08 PM
well,, since I know no technical terms.... there was one thing with springs on it... another piece that went over that with (I think) hex bolts, and then the cover with that hook thing that went around the thing with the hex bolts... sorry for not knowing the terms
Old 10-04-2004, 04:11 PM
fast924S's Avatar
Sounds like the clutch, can you take a pic? Your gonna need to line them all up so that the drive shaft can slide into them
Old 10-04-2004, 04:28 PM
will take pics tonight or tommorow... thanks for the help
Old 10-04-2004, 04:31 PM
