gtroth's Avatar
Are ContiExtremeContact tires anygood?
I am considering the ContiExtemeContact 225/60-15's because they seem like they might be pretty grippy in the rain and maybe do ok in some snow. I'm replacing the Pirelli P4000 SuperTouring 215/60-15's that are starting to scare me they're so slippery.
Does anyone know if they are any good for our cars? The TireRack survey rates them pretty high.
1995 993C4 guards red
1988 944S alpine white
Old 10-06-2004, 06:46 PM
Ornery Bastard
Personally I am very fond of the Bridgestone Potenza RE950. I had them on my 924S and they were good tires and surprisingly good (for a 3-season tire) in the snow. I've always been a Bridgestone/Firestone fan though.
I remember having heard some good things about the Conti's too, but nothing about snow traction. I can't imagine they would be better than the RE950's in snow, and most likely they won't be as good in snow given the Conti's performance category, but I haven't had any experience with them so I cannot verify.
Aaron
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 10-07-2004, 07:12 AM
gtroth's Avatar
That TireRack survey rates the snow perfomance pretty high - higher than the RE950's actually. But hey - it's just a survey, probably not alot of 944s responding. So who knows.
Old 10-07-2004, 06:47 PM
Ornery Bastard
I hadn't looked them up, you're quite right.
That's surprising since they're one performance class higher than the RE950's, which usually means that snow performance is sacrificed slightly for dry performance. Honestly, they look like great tires.
Aaron
Old 10-07-2004, 07:30 PM
gtroth's Avatar
Yeah, they look good don't they - and $72ea. Theirry75 was considering them recently so I took a look. I was kind of hoping someone here had checked them out already - maybe I'll be the guinea pig.
Old 10-08-2004, 08:14 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
Never heard of them. I gotta agree with aaron, get Bridgestone RE950, I never had a big problem with the snow of SD. Just careful when it gets over a couple inches, the car WON'T go up a hill, but you're fine everywhere else.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 10-08-2004, 10:01 PM
gtroth's Avatar
Alright, after reading the customers' reviews for the Conti's on TireRack, there seem to be a lot of problems getting these to balance, and with flat spots after sitting for only few hours. A few reviewers thought the side walls were soft. Of course many reviewers liked them, but I'm now put off.
The only thing I don't like about the RE950's is the HR speed rating for 15" rims. Are the side walls stiff enough...
Not too many options, I'm finding.
Old 10-14-2004, 04:59 PM
Ornery Bastard
Remember, regardless of what the tire salesman tries to tell you, speed rating is just that, speed rating. Speed rating does not rate cornering ability nor anything else aside from the maximum design speed.
Personally, I really liked the RE950's. They aren't a track tire, but they are excelent for people who push hard on public roads.
Aaron
Old 10-14-2004, 08:00 PM
meister member
speedracing944's Avatar
i wouldn't go with the 225/60/15's unsigned from the rennlist forums was at my house on saturday and his car was equiped with 225's and i ate him alive on the back roads. He couldn't keep up because of the side wall flex was too much. I would stick with the 215/60/15 unless you need the additional ground clearance for snow.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-14-2004, 08:47 PM
gtroth's Avatar
Yeah, I was only thinking of the 225s because that's what the Contis were. 1/4" difference in the sidewall makes a big difference, though, huh?
Aaron - I don't ordinarily talk much to tire salesmen. Sidewalls are not generally stiffer for higher speed rated tires? Thought they were. Are you running the HRs (on 15s) or the VRs (on 16s)?
Old 10-15-2004, 03:55 PM
Ornery Bastard
Sometimes the sidewalls are stiffer, sometimes they aren't.
It's just heat-handling ability really. Yes, higher speed rated tires tend to have stiffer sidewalls, but that's not because of speed rating, rather it's because tires with high speed ratings are pretty much exclusively high-performance, and higher performance tires have stiffer sidewalls.
My 924S was running the stock 195/65 R15 size.
Aaron
Old 10-15-2004, 08:41 PM
