Registered Loser
Is bad power steering a safety hazard?
My power steering system seems to have "gone to the light." I tried retensioning the ps belt and searching for leaks to no avail. I'm guessing either the pump or the rack is toast. But honestly, I don't mind the hard steering. In fact, I think power streering is a waste of hp in a sports car. So assuming I'm fine with the extra steering effort, is there anything here that can or will break and cause a safety problem?
Owner of a wrecked 944
Old 10-12-2004, 10:25 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
If it's only gone to one side, then it's the gear in the steering rack. The gear has some springs in the side of it that allow the power assist to work. The springs sometimes break or just wear out and if you can find someone with just a leaky rack they are selling and take the gear out and put it in your rack, it will work correctly again. Finding the part is hard though. Personally, I'm looking for a manual steering rack insntead for mine.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-12-2004, 11:56 AM
Cars & Coffee Killer
legion's Avatar
The steering in these cars is still relatively stiff, correct? (Compared to, say, an American car.) I've only driven the 944 S I ended up buying and a 944 Turbo, and their steering was identical.
5 liters of VVT fury now
-Chris
Old 10-12-2004, 01:29 PM
fast924S's Avatar
Send a message via AIM to fast924S
No its not a safty HAZARD as long as you remeber its like that, also I would keep the fluid in it just so then stay lubed
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-12-2004, 01:54 PM
flangermog's Avatar
Is it permanently not working? Mine occasionally doesn't work if the car has been sat (especially in the rain) until i'm fully motional. That can catch me out a little sometimes as I have to turn sharply out of the driveway onto a main road... But if it's permanent then I agree with the above...
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 10-13-2004, 02:48 AM
Parrothead member
VINMAN's Avatar
My P/S adjuster broke on me, so I was without the P/S for a while
to be honest, I liked the way the car felt with out it, . Out than parking, it was fine.
Vinny
Old 10-13-2004, 04:58 AM
Registered Loser
Thanks very much for the replies. I feel a lot better about it now. Franky, I agree with VINMAN. I never much liked power steering and I am just as glad to be rid of it so long as the car continues to steer. So until a manual rack magically appears for cheap on eBay, I think I'll just pretend the power steering was never there.
Thanks!!
Old 10-13-2004, 12:03 PM
tifosiman's Avatar
Thanks!!
If you do find one on ebay, make certain it is from an 83 944 (not a 924 rack, they don't fit).
Also, keep in mind that you will need custom tie-rods because you have a late offset car. The factory ones for manual late-offset cars are NLA.
Once you have that worked out, you'll need a new intermediate shaft (again for an 83 944). Used ones tend to have slop/play in them. I have two bad ones in the garage. Once I get my shop press installed, I am going to see if it is reasonable to attempt to rebuild them (no one I know does this at the moment).
Good luck!
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 10-13-2004, 02:03 PM
jm951's Avatar
If it's just the pump that's bad, keep fluid in the resevoir and it won't hurt to drive it like that for a while. Mine was out for over a year and other than a higher steering effort when parking, it wasn't bad. In fact, I'm planning on ditching my ps on the 951 and going to a 931/924 rack. Before you guys tell me it won't work, I'm modifying a late xmember to accept the 924/931 rack. Since I already have a set of tie rod ends from an 86, this should work out ok.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 10-14-2004, 07:36 AM
Registered Loser
Aw man, you can't just say that and leave us hanging!! Ya gotta explain how your modding the steering so we can try it. Got any pics of your project?
Old 10-14-2004, 02:45 PM
hoff944's Avatar
Send a message via AIM to hoff944
replacing your rack with a rebuilt rack isn't that expensive unless you just want the extra hp. You would only get about 1 to 2 hp. I can't imagine any more than that.
79' 911SC
98' 911GT2 Evo RC
84' 944 (Sold)
Old 10-14-2004, 03:29 PM
jm951's Avatar
Replacing the ps unit with a manual will only pick up about 1 or 2 hp by reducing the parasitic loss. Where you gain further is taking off weight, namely the pump and associated plumbing and the manual rack weighs less too.
Pix will follow on the project, I have a fun run to do this weekend, hey we gotta have priorities.....
Old 10-15-2004, 08:27 AM
hoff944's Avatar
The whole unit weights maybe 5lbs. 10lbs with the pump?
79' 911SC
98' 911GT2 Evo RC
84' 944 (Sold)
Old 10-15-2004, 07:12 PM
jm951's Avatar
To paraphrase Colin Chapman "to go faster, add lightness" Every pound counts. Those subs that some kids like really add up, as does the amps, and other components. If you've never done a vehicular diet, you'd be amazed at how much stuff weighs. So, 5 here, 10 there, and reduced plumbing, less parasitic drag and presto, instant effective hp not being wasted dragging stuff around. My son's Scirocco has a GVW of right at 3k lbs, that's right, 3000. We've put it on a very severe diet and have it down to 1700 at the moment. With the original 1.8l sohc engine, it would do an honest 0-60 in 6.5sec. That's trending into 951 territory with no engine modifications, just ditching heavy stuff.
Old 10-15-2004, 09:34 PM
