Still looking for motor installation help in MA/NH area... WILL TRADE OR MONEY
hey I am looking for help installing my motor into my car. I have an 86 944 getting an 88 motor. I've got the motor and the car and all I need is help putting it all together by someone that knows what they are doing.. I was told people here would be able to help me out. I can pay a little bit.. I also have the old motor, so if you want an extra block or any of the parts (I dont know whats good you'll have to check it out) I was told by someone that the car can be on the road and running in 5 hours by him... so anyone that can help me out would be greatly appreciated..
Old 10-12-2004, 02:22 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You know............ I would help you ....
but I don't think it would be practical paying for my flight.
...........but we can help YOU......get it back together....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-12-2004, 05:28 PM
ok well lets start with getting that arm on the front changed... I assume I have to take all those gears off then pull off the plastic, then change the arms and put all the gears back on? again... if there is ANYONE in the area that can help me out please let me know!
Old 10-12-2004, 05:53 PM
well I was kinda hoping to trade parts like that for help getting the new motor put in... but if I get it in and those parts are still available I will let you know! thank you.
Old 10-12-2004, 06:15 PM
ae1969's Avatar
Step 1. Fix the broke piece
the things I mention refer to www.clarks-garage.com for clarification
Look up the section on replacing front seals.
That will explain how to release the crank bolt, rollers, tensioners, rear black timing belt cover etc.......... and then you will have access to that lower balance shaft housing (the part you have circled)
On that picture you are showing you have one dilemna. How to remove and torque down that crank bolt. Normally you would lock the crank (with a flywheel lock). You dont have the flywheel on yet.
You see if you try and remove the crank bolt the engine wants to turn over....... That bolt is at 150lbs. I would install the flywheel/clutch. You can then rig it up to lock the crank in place while you remove the crank bolt.
I would replace all the front seals at this point and check all the rollers, tensioners and waterpump for wear..
This should get you started........ http://www.clarks-garage.com/shop-manual/eng-14.htm
Pay special attention to the other procedures section on that page.
Old 10-12-2004, 06:20 PM
jeez that looks really complicated... I really hope someone in the area comes through.... I appreciate the help I just really dont want to mess anything up. I put the clutch and bellhousing on the new motor.... but I just put it back on the way it would bolt up... I didn't line anything up with anything... so I dont know if I did it right...
Old 10-12-2004, 06:27 PM
ae1969's Avatar
Its not that complicated. It just takes time to look things over.
So while you wait for someone to step up......... tackle one section at a time.
It seems overwhelming at first but just take little bites and understand what you are doing.
Just post your questions here. There are no dumb questions and we all learn from the steps you take. So get at it........start reading.
The assembly you have left is pretty straight forward. Just don't assume ........ask.
So lets start with the flywheel and bellhousing if you like.
Start another thread if you like .......take a pic of what you did and how you did it. Torque specs etc........ or what you are planning on doing. Maybe ask before you do.
Old 10-12-2004, 06:33 PM
fast924S's Avatar
Send a message via AIM to fast924S
Yes Eric, I told you if you need help just post we can walk you threw the steps, Kinda like a copilot, all you gotta do is ask man, Also you might want to get your self a HAYNES manual to help with specs and stuff.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-12-2004, 07:30 PM
fast924S's Avatar
P.S Kinda OT, As much as I am agianst stickers that say what kinda car you are driving, I think I like the one on you windsheild
Old 10-12-2004, 07:31 PM
haha thanks man I didn't put it there but I like how it looks.. I think I may keep it.. not that anyone else will see it anytime soon at the rate I'm going!
Old 10-12-2004, 07:33 PM
