944freak's Avatar
Send a message via Yahoo to 944freak
speedo not working
on my 83 na the speedometer isnt working. I know a cable runs through the hub and out the spindle. What makes the cable turn. I think i am missing a piece or something all i have is the end of the cable sticking out of the spindle and it has a small clip retaining it inside.
1983 944
Old 10-12-2004, 09:12 PM
Just thinking out loud
mattdavis11's Avatar
The wheel bearing dust cap has a square hole, the end of the speedo cable is square the clip holds them in place. Now for the answer, the dust cap turns with the wheel. More than likely, yours is broken somewhere under the protective sleeve. To test it, pull the dust cap and put the end of the cable into a drill, and spin it. Your's may have become disconnected at the back of the instument gauge, check that as well.
91 FJ80
84 Ram Charger (now gone)
Old 10-13-2004, 08:01 AM
That Guy
Techno Duck's Avatar
Yes, the cable can be a pain in the neck to remove. Just pry the dust cap off with a large screwdriver. You need to use an allen key to loosen the clamp to change the cable.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-13-2004, 11:52 AM
Anyone have any tips on how to get the cable to go through the dust cap when the times comes to put it back together?
Nigel
'87 924S 5sp
Slowly recovering from a warped head
Old 10-13-2004, 02:57 PM
944freak's Avatar
thanks guys, my wheel has the wrong dustcap on it, and the other one is missing a dustcap. Anyone know where i can get one or a way to make it work elsewise.
1983 944
Old 10-13-2004, 04:46 PM
