Enthuzed1's Avatar
Location: Sometimes Sacramento, Most of the time Concord, CA
Question 944 Stereo Power Connections
Hey there everyone, i love this forum, lots of very useful info. I have a 1987 944 and when i bought it, it came without the stereo system. It was pretty obvious the previous owner had an amplified system in it and his wiring was all messy. I plan to channel new wire to the speakers so all i need is to find the ignition, illumination,constant power, ground, antennae, etc. to power the deck. I know this connector is the right one, so can anyone tell me which wire/color is for what? Thanks a lot...(i apologize if im being an annoying newb)
Old 10-12-2004, 11:10 PM
That Guy
Techno Duck's Avatar
I have the Crutchfield wireharness diagram at home...but im at school right now . I do have the factory diagrams however.
Starting from left to right....
Ground Connection Plug
Ignition Lock Term. R Plug
Lights
Antenna Amplifier (Automatic Antenna)
Permanent Positive Term. 30. Plug
Alarm Contact CD-Player
I installed an Alpine headunit last saturday...from what i remember the Ignition Lock Term. R Plug is for the switched powersource, lights control the dimmer function on the face (if your headunit supports that) and the Permanent Positive Term. 30 Plug is for constant power so your stations and presets are saved.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-13-2004, 06:32 AM
Enthuzed1's Avatar
hey thanks techno, now in the picture, i have 2 brown wires, and 2 red and black striped wires going to the same connection, does it matter which one i use for ground and antennae amplifier? also, from your description, it looks like i don't have the alarm contact, right?
Old 10-13-2004, 11:26 AM
That Guy
Hrm, not sure which you want to use as the contact. I would say splice both wires, but dont quote me on that.I used a wire harness which connected everything up nicley to the that stock adapter. I dont think mine had the alarm contact either, so nothing to worry about.
Jon
Old 10-13-2004, 11:47 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
1 Brown - Ground (large pin)
2 Red - 12v switched power input (large pin)
3 12v illumination power input (from pin 4)
4 12v radio-switched output (to pin 3)
5 12v radio-switched output (to power antenna)
6 Permanent 12v input (to maintain memory)
as shown here:
http://forums.rennlist.com/rennforums/showthread.php?t=99381&highlight=944+radio+wire+colors
http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=86734
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-13-2004, 12:41 PM
Enthuzed1's Avatar
Hey guys, thanks alot for your help...now only, if i had money for all the audio equipment i want..........
Old 10-13-2004, 11:06 PM
