power steering
dear all
i have a 86 924s
on cold mornings the power steering makes a slight grinding noise. once the engine has warmed this goes. i have checked the reservoir and it has enough fluid but there are lots of tiny bubbles.
any ideas, hellp is much appreciated.
simon
Old 10-15-2004, 01:53 AM
flangermog's Avatar
Could it be you have air in the system? Your rack could have a tiny leak and be letting in air...
Check the belt too. Mine slips when the car is cold (which squeaks). It is quite common for the steering to make a noise when turning whilst not moving or moving slow. Especially when cold.
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 10-15-2004, 02:18 AM
adrian jaye's Avatar
sprincey,
sounds also like the system needs bleeding.
this is the procedure for the 44, but should work equally well for you.
1> with cap off
2> switch engine on and as it catches, switch it off. do this again
3> with engine running, turn gently from lock to lock, at least 5 times. DO NOT apply to much force on the end of each lock.
also try changing the fluid.
and check for leaks
HTH
Ade
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-15-2004, 06:03 AM
Official Sponsor
vital-transform's Avatar
bubbles useally means a bad pump
1988 - 924S Guards red, auto trans
Old 10-17-2004, 08:21 AM
