sunroof lifts at speed
One corner of the sunroof in my 1989 944 Turbo lifts approximately 1/4" at "highway" speeds. Does anyone know what causes this and how I can fix the problem?
Old 10-19-2004, 02:31 PM
livewirevoodoo's Avatar
I have an 87 944na.. If its the same design as mine, I encountered the same issue before. My power sunroof option has never worked, so I dunno if that affects it at all...
Basically, what I needed to do so the sunroof wouldnt lift at highway speeds is make sure that the two metal curved lifting arms in the back of the sunroof area securely hooked into the sunroof panel's housing.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 10-19-2004, 02:41 PM
PorscheFreak's Avatar
the lifting is caused by the pressure difference between the inside and outside air. moving air causes lower pressure so the air inside tha car is higher than the air passing over it. your hook arms are definitely not hooking.
1987 944 NA
India Red
Old 10-19-2004, 04:16 PM
gtroth's Avatar
One rear corner? Probably the sunroof gear that drives that side's lifter arm is stripped as usual. There's a good tech article somewhere (here or at clark's garage I think) that will tell you how to swap it out.
1995 993C4 guards red
1988 944S alpine white
Old 10-19-2004, 04:25 PM
TCMdocs944's Avatar
www.clarks-garage.com
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-19-2004, 04:39 PM
will944's Avatar
Send a message via AIM to will944
crack a window....at least then it won't fly off!! Bernoulli's principle is a b!tch sometimes.....haha
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 10-19-2004, 05:09 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Hehe, sometimes I accidentally release my roof, and it lifts up on the highway.
Since it's only 1 corner, it sounds like only 1 arm is not locked in place.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-19-2004, 06:34 PM
Is'nt it that you can only release/lock the sunroof if the ignition switch is in the second position accessories ON.
Opening/closing is only possible if ignition is ON or in third ignition switch position. At least that's how mine operates.
One of your sunroof lifting arms is possibly not in the locked position. Could be due to 2 reasons.
1. Sunroof plastic gear is stripped.
2. If plastic gear is ok, the lifting arm is not in the middle of the track's bent section in the locked position.
The track is located in the back edge of the sunroof. If you look at the track, there is a bent section in the middle.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 10-20-2004, 12:59 AM
Wow, I never expected so much help in such a short time: thanks guys. I will check the lifting arms to assure they are properly hooked in and examine the gears for wear. Thanks again, you have been a great source of information.
Old 10-20-2004, 07:21 AM
TCMdocs944's Avatar
Thats what we do...
Welcome to the board.
Old 10-20-2004, 12:11 PM
