fast924S's Avatar
Send a message via AIM to fast924S
Fiberglass or Carbon Fiber
Ok as many of you know I am redoing my 87 924S aka Project red blaze. It will be undergoing many changes, body and engine. For the most part I have a good idea on what I want to do but I seem to be stuck on one thing. What should I use for replacment body parts?? Carbon fiber or Fiberglass?? I know carbon fiber is $200-$300 more than fiberglass but it is alot lighter. Has anyone used carbon fiber before??? WHat would the fit be like??? Can you paint it??? I need Pro's and con's of the two.
Ohh yea, I dont want to hear That its a waste of money to do on a NA or any BS like that, all I want is some usefull Info. Thanx guys
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-21-2004, 06:11 PM
livewirevoodoo's Avatar
Maybe this will help.. How to: Make Fiberglass and Carbon Fiber Parts
seems to go into alot of detail about both materials. Not 944 specific tho.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 10-21-2004, 07:14 PM
entertaining the idea
UconnTim97's Avatar
I'm not sure how the two compare with each other for painting, etc...but I would think if you want to save weight, go all the way while your at it.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 10-21-2004, 08:45 PM
Custom User Title
rammstein's Avatar
No way man- nobody should go after you for cutting weight. I think it would be amazing to strip serious weight off of these cars. I'd like to see the results.
Old 10-21-2004, 10:35 PM
Carbon-fibre all the way! Strength-to-weight is about 5-10x better than fibreglass. That's for fully-optimized configurations, so your mileage may vary. Not sure what you're making, but you want to use:
- high-modulus unidirectional carbon-fibre (EMS) for best strength. Align fibres in direction of load. Preg-peg is best.
- epoxy resin (avoid low-strength polyester)
- make mold and plug for pressurized mold, yields lighter and stronger part with higher fibre-to-resin ratio than hand-layup.
Old 10-22-2004, 12:06 AM
fast924S's Avatar
Well I think I will be replacing fenders, hood, front valance and some other odds and ends with Carbon finder, It should drop the weight alot BUt I gotta start running the numbers to see if I have enough money. I wll also be removing the rear seats and AC system
Old 10-22-2004, 02:13 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Are you planning on making the panels yourself?
Any idea what this would cost in materials?
I would love a complete carbon fiber shell!!!
If you want to make something how about we start with a more aggressive rear spoiler. I wanna see how it comes out.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-22-2004, 02:28 PM
Cars & Coffee Killer
legion's Avatar
Cutting weight is good but...
  • Fiberglass is cheaper to replace than carbon fiber (you knew that).
  • Because carbon fiber parts are more expensive to replace, they are more expensive to insure. You don't have to tell your insurance company, but they won't replace them either if they get damaged.
I'm going to go with fiber glass eventually. That's my 2 cents.
5 liters of VVT fury now
-Chris
Old 10-22-2004, 05:16 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
I was planning on doing some fiberglass parts myself, starting with making some different bumpers probably. Then moving on to other things, let me know what you decide on!
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-22-2004, 06:05 PM
meister member
speedracing944's Avatar
With carbon fiber if you don't paint it looks cool. So you can save on the expensive and heavy paint job. Go all the way while your at it. Go carbon and post plenty of picks and info.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-22-2004, 06:46 PM
fast924S's Avatar
Well the problem with not painting it is some of the car will be red and the rest carbon fiber I dont think it will look right
Old 10-22-2004, 08:17 PM
a.n.other's Avatar
Have you seen the latest Grassroots Motorsports magazine? It's got a 5 page spread about DIY carbonfiber - I don't have a scanner, else i'd get you a copy of it. It's also got another good article about removing stubborn nuts and bolts.
Andy
Lowered '84 944 no longer smokin!
Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!)
http://photos.yahoo.com/shineyblue944
Old 10-22-2004, 11:23 PM
fast924S's Avatar
How do I get Grassroots Motorsports??
Old 10-23-2004, 08:49 AM
Verruckt's Avatar
www.grmotorsports.com
I have always liked there mag, going fast on a budget.
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 10-23-2004, 09:26 AM
Send a message via AIM to Trevor
What about weight distribution? Are you going to do anything to try to keep it close to 50/50?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 10-23-2004, 10:45 AM
fast924S's Avatar
I will try the best I can, Like I said the rear fenders will be changed and the rear seat will be comming out. I dont think It will be loosing so much weight that it will mess things up
Old 10-23-2004, 01:15 PM
seaboltman's Avatar
last i knew, Painting carbon fiber is a bit*h and a half and REALLY expensive to do. If you have the $$$ i would say go for it but i wouldn't stap stuff on until its painted. You could alwayse do it one piece at a time, and then paint. will keep your car getting progressivly lighter, and looking good at the same time
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 10-23-2004, 09:11 PM
