-   -   Random Questions.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/188415-random-questions.html)
livewirevoodoo 10-21-2004 08:03 PM
Random Questions..
so i got the day off tomorrow and planned on spending the morning handling some odds n ends...
- changing differential fluid... its an automatic, so only a fill hole, no drain hole. can i use a cheapy $3 autozone handpump to get the old stuff out?
- shifter sound deadening.. is there an off the shelf product i can put under the shifter housing/boot to quiet it up some? dynamat or something?
- phone dial refurb. the hand painted centerpieces came out real nice.. time to refinish the wheels. while i have the wheels off is there any way to clean up the calipers w/o having to remove them? they're looking a lil crusty...
that about does it. as a side question, does anyone have an experience with automatic starters? is it possible?
AFJuvat 10-21-2004 08:10 PM
1. Yes, a handpump is fine
2. Fiberglass works well
3. Brake cleaner (aerosol) and a wire brush
WHat about automatic starters?
AFJuvat
livewirevoodoo 10-21-2004 08:19 PM
Much appreciated Juva, thanks.
Are automatic starters do-able on 944s... Would they put any undue strain on a 17 year old electrical system?
AFJuvat 10-21-2004 08:27 PM
Couldn't tell you, never seen one installed to be perfectly honest
As long as your wiring was in good shape, I would imagine that it would not hurt the car
Just get a good wiring diagram if you do it - German wiring colors do not match US wiring colors..
AFJuvat
fast924S 10-21-2004 08:38 PM
Yo lime where in NEwhaven Are u
livewirevoodoo 10-21-2004 10:23 PM
I'm right around the corner from SCSU.
strath44 10-22-2004 03:10 PM
When you mention automatic starters is that by a remote keyfob or a press button? Just wondered know of a few sytems but don't know what they are like think there is one made by Kenlowe with the main benifit to it all being it has a timer too so you can start the car at 7.55 am to got to work at 8.00am. I personally don't like the sound of them would be worried about leaving the car in gear etc (auto would be okay I suppose). Also used to be told that you should let the car warm up before driving now a few people tell me its better to drive it straight of as it circulate the oil better??
livewirevoodoo 10-22-2004 06:08 PM
Strath - I was referring to the keychain fob types. Winter mornings can be below freezing here, and its a good 5-10 mins before the car is up to temp. I've heard the get in and drive advice too, but IMO the engine sounds a little too grumpy that cold for me to feel comfortable with.
